Results 1 to 5 of 5
    Jun 2022
    Ontario
    Default 2022 F3S battery access - what about the 2 cables thru the frunk bucket?
    The Operators Guide states that you should remove the front storage compartment bucket but says nothing about the two cables coming through the backside of the bucket which prevent the bucket from being lifted very far. What should I be doing?
    Feb 2020
    CT and ME
    Partially lift the bucket and pull the cables out through the hole.
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
    Jun 2022
    Ontario
    Thank you and please pardon my ignorance but do you mean pull the cables out of the bucket or into the bucket? There doesn’t seem to be enough room to get a hand behind the bucket to pull the cables out of the bucket.
    Feb 2020
    CT and ME
    Push the cables out of the bucket. Once they are out the bucket will lift up.
    My Mods:
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Viking saddle bags
    Third pegs
    Mad Stad windshield
    Garmin Zumo XT
    Heated gear wiring
    Jun 2022
    Ontario
    Thank you very much for the clarification.
