Results 1 to 7 of 7
    Member vetman03's Avatar
    Oct 2020
    Lancaster, PA
    Default RT-L Liner weather strip torn away from liner - any fixes?
    Just bought a 2013 RT-L. Great deal in excellent condition, low miles. In the frunk there is a liner that has the BRP logo on it. I cannot tell if this was a factory item or added afterward. Anyway, around the top edge is a U-Channel with a round rubber tube that was glued to it. Just about all of the tube has torn away from the U-Channel. It was a weatherstrip or cushion that touched the underside of the frunk lid. I cannot find anything like a part number of either the original insert, or just the weatherstrip to replace it. I may get some Gorilla glue and try to carefully glue the tube back on to the U-Channel.
    Anyone else have this situation? Any other ideas on replacing or repairing this weatherstrip?
    Last edited by Peter Aawen; 08-30-2022 at 01:17 AM. Reason: Expanded Title to briefly ask the question ;-)
    Sep 2014
    USA
    Check Lamonster or Spyder pops
    Nov 2015
    Chardon, OH
    Quote Originally Posted by vetman03 View Post
    That's an OEM part. Neoprene seal. Item number 330.
    https://www.canampartshouse.com/oemp...s-front-fender
    Yes, an after market seal may be less money.
    Doug
    ”Freedom is not a loophole”
    Oct 2020
    Lancaster, PA
    Hey, thanks for the quick response and information. I can take it from here. Thanks again!!
    I had checked Spyder Pops and Lamonster already. Somehow missed this site completely in searches.
    Bossier LoUiSiAna
    Trick is look at something else (FARKLE) first https://spyderpops.com/replacement-w...odels-2010-19/
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    RT-S PE#0801 timeless's Avatar
    May 2010
    Punta Gorda, Florida
    I have a 2010 RT SE5 with the OEM liner like that and I have re glued my weather stripping on several occasions. I used Weldwood contact cement and it holds up pretty well.
    Jul 2014
    Mint Hill, NC
    That frunk weather strip seal on my Spyder gave up the ghost not quite a year ago and I replaced it with one from Spyderpops for $22.95. The best thing about Harvey's replacement is it's just a bit stiffer than the OEM one, so when I turn the key to unlock the frunk the seal serves as a spring and the frunk lid unlatches by itself.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
