Results 1 to 6 of 6
    Active Member USAF's Avatar
    Aug 2022
    NY
    Default What options to replace driver foot pegs for Floorboards?
    What floorboards are you guys replacing your driver foot pegs with? This will be on a 2012 RTs. Will later year OEM floorboards work or does this have to be aftermarket?
    Thanks!
    Last edited by Peter Aawen; 08-30-2022 at 09:06 AM. Reason: Removed spaces before punctuation so text to voice can read.... :-/
    Active Member Eviltwin's Avatar
    Oct 2017
    Portsmouth VA
    I made a set for my 2010. I think the options on the older bikes may be getting a bit sparse. Here is what I did: https://www.spyderlovers.com/forums/...ore-(Many-Pix)
    This was about 4 years ago and they are still holding up fine.
    2019 BMW C650GT, 2010 Spyder RT-S, 2009 BMW R1200RT,(sold) 2009 Honda Silverwing (Sold), 2009 Kawasaki 500 Vulcan (Sold)
    2010 RT SE5 , Black
    Nov 2018
    Waynesboro, PA
    My Spyder
    2012 RTL , Brown
    Member Arachnerds's Avatar
    Mar 2021
    South Dakota
    We have a 2011 that had pegs but we wanted floorboards too. There were nice looking 6 1/4" long ones from Lamonster ..... https://www.lamonstergarage.com/comm...-rt-lamonster/ .....but we went with some longer ones from Pierre at canamspyderaccessories.com https://www.canamspyderaccessories.c...-rhino-lining/ We also ordered the "floating" highway pegs at the same time. Love both!
    2011 Spyder RT Limited
    Active Member Tatonka's Avatar
    Jan 2018
    North Carolina
    If anyone sees any Kuryakin Widow pegs..rsvp
    Jan 2018
    North Carolina
    Any of those floor boards work with a manual trans?
    Some time ago I found some for my 13 RT but after mounting I found I couldn’t get my toe down to initiate the shift. So I have a peg on the shifter side and a board on the brake side which works out quite well.
