Results 1 to 19 of 19
    Active Member MrSchaefer's Avatar
    Jan 2020
    Minneapolis, MN
    Cool F3 Trunk Pop - Problem Fixed
    Hey All,
    In chatting on the F3 Spyderlovers group, it seems there are a lot of riders out there who, like me, had to use two hands to open the Frunk on the F3. On my 2013 ST when you released the trunk lid it would make an audible "pop" sound and then you could walk around to the front and lift the lid. On my F3 releasing the trunk lid required using one hand to pull up on the lid while simultaneously turning the key with the other hand.
    Chatting with other f3 owners about half had the two-handed experience and swore that was how it was meant to be.. the other half had the "pop-up" experience. So I did some experimenting and found that the two-handed experience is caused by a poorly installed hood pin that is completely and easily fixable. I put together a video explaining the issue and the fix in the How To section:
    https://www.spyderlovers.com/forums/...-Can-Am-Spyder
    I'm now a "popper" and so very happy - HATED the two-hand thing to the point where I stopped using the frunk altogether aside from Dairy Queen runs (fun fact, the beverage carrier from Dairy Queen fits EXACTLY in the frunk and will hold up to 4 blizzards perfectly)
    2021 Spyder F3-T - Pearl White
    2021 F3-T , Pearl White
    Aug 2020
    California
    Lots of thanks for posting this! Mine requires 2 hands and I hate that.
    Thunder's just the noise. Lightning does the work.
    Jan 2020
    Minneapolis, MN
    Interesting.. looking through the Parts Fiche there IS supposed to be a spring in there.. which is not there in mine and from my experimentation is not strictly needed?
    I'm going to order one.. maybe I'll get it sometime in 2023 - will update if/when I do.
    Jan 2020
    Minneapolis, MN
    I can't imagine what stops the spring from popping out if/when it is installed. But now I'm curious.. and for $4.. I'll experiment some more
    Jun 2022
    N.E. Fl
    Thanks for an informative video!
    2016 F3-T , Blk/Rd
    Apr 2018
    Texas
    Just watched your video. I am putting this at the top of my DIY projects on our Spyders here at home. Very impressed with your video and your presentation.
    Thank you
    John
    Active Member hut1's Avatar
    Sep 2009
    Greenwood, DE
    Using the two-handed process never really bothered me, but I decided to make this adjustment while doing some cleaning and general "looking around". Your demonstration was great, and now I'm a "popper" too! Thanks!
    Skip H.
    '21 Can Am Spyder F3 S
    '97 Honda Goldwing w/Hannigan Astro 2+2 sidecar
    [img]
    I'm late to this party ( I don't have an F-3 ) ..... but after watching the video I realized the OP probably never rode or owned a GS or RS ..... back then the answer was to buy a spring and put it on the Post ..... Frunk popped open all the time ..... Mike
    Ohio
    Just a quick note concerning this fix. The video of DIY dad mentions at time marker 4:00 about the locking pin will want to slide down when it is loosened. **This is important to be aware of.** My locking pin slid down when I loosened it and I didn’t put it back into place when I was retightening it. When I shut the frunk to check its operation the locking pin was no longer aligned and it was extremely difficult to get open. I thought I might have to remove the entire front Tupperware to open it. I began pulling up on the frunk lid harder than I was comfortable until it finally came open. The latch continued to work but the pin was apparently lodged under the lip of the access hole due to it being out of alignment.
    Besides the above issue, which was my fault, the adjustment was made and now when I turn the key to unlatch the frunk I can release the key, walk around to the front of the bike and pull up on the lid.
    Poasttown 2019 F3L
    Jul 2022
    pa
    Where do the flats go on the pin I got mine all screwed up. help.
    Active Member VitoNam's Avatar
    Nov 2018
    NW Minnesota
    Yep, good old Minnesota ingenuity here! Good Job!
    Apr 2018
    Texas
    Tekslk, the video says the flats go on the top and bottom (not sides).
    Hope that helps
    John
    Jun 2022
    N.E. Fl
    It worked like a charm, Thanks once again!
    2016 F3-T , Blk/Rd
    Jan 2020
    Minneapolis, MN
    I do believe there SHOULD be a spring in there (at least based on the parts fiche) - but that they either don't have a retainer clip or anything to hold it in or they just simply don't install it in the first place - Either way - I'm glad this is working for others as well!
    Jul 2022
    pa
    I got it thanks
    Feb 2020
    illinois
    Have had my 2022 F3L for about a month after trading in a 2020 RTL. Had no problems with the first one. the 2022 worked fine up to two days ago when it took two hands to open. Found this post and after looking at video, went out and looked at the frunk striker position. Found that it was slightly misaligned according to the video. Adjusted it's position and now works like it should. Noticed the set nut holding the striker was not tight as i thought it should be and thinking that it became misaligned because of the nut not fully tight.
    Jan 2020
    Minneapolis, MN
    That's very possible - if the locking nuts were loose the vibration could have easily caused the pin to migrate a bit. Glad the video helped!
    Mar 2015
    Tacoma WA.
    Just did mine. Works like a champ. You don't have to turn the locking pin much, and make sure the flat side faces the upper edge of the lid.
    2017 F3-S Daytona , Yellow and black
    Active Member RickWB's Avatar
    Jul 2019
    Duncan, British Columbia
    Thanks, did the mod today.
    2019 F3 base
    Shad saddlebags with Admore led light kit
    BajaRon swaybar
    Hopnel mini bra
    BRP driver's backrest
    Madstad windshield
    Ultimate floorboards
    CanAm Spyder accessories rear shelf with LinQ adapter
