Results 1 to 18 of 18
    May 2019
    Mt. Juliet, TN
    Default What to do with catalytic converter? Sell it, or keep it?
    Deleted OEM catalytic converter. Can the old converter be sold? Or should an owner keep it for possible future needs?
    Last edited by Peter Aawen; 07-10-2022 at 07:26 PM. Reason: Caps & expanded title to briefly state the question...
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by seagravesg View Post
    I kept mine so if I decide to sell the bike in the future, I can give it to the new owner.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Dec 2015
    Oakley Utah
    Hang onto it. Or sell it. They're worth a lot of money.
    Don't dispose of it!
    2014 RTL Platinum
    Mar 2022
    Huntsville, Alabama
    You who delete them, do you know what it does?
    I could not see going out of my way to make more pollution.
    2012 Blue Spyder RT Limited
    Sep 2015
    Quote Originally Posted by Tonylmiller View Post
    Good for you.....Glad to hear!
    Sena SM10 BT Dongle
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    Bossier LoUiSiAna
    If keeping recommend tag/label it accordingly. Including vin# somehow or another (Helps the memory filing process too)
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Oct 2016
    Faribault, MN
    Keep it, when I sold my '13 I reverted it back to stock for the new owner to have the choice and joy of farkling their way.
    Last edited by Peter Aawen; 07-11-2022 at 12:58 AM. Reason: Removed off-topic provocative comment!
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Jan 2021
    northeast pa.
    Keep it. I also did the cat delete, but I've switched back and forth, I put it back on for now, I like it quieter... only takes a couple min. to change. I also would put it back on when taking it to dealer under warranty.
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
    Sep 2017
    INDIANA, USA
    Default Keep the converter
    ...I agree with what others have Posted.
    Definitely keep it a and have it labeled so you know what it is moving forward.
    Stay Healthy. ....
    ENJOY YOUR LIFE WITH A SPYDER
    Aug 2019
    Stoughton, WI
    Keep it..
    2022 RT Sea To Sky
    Active Member C. Lee's Avatar
    Feb 2016
    Silver Lake, OH
    I put mine back on my RTL because I didn't like the exhaust smell without it. Chris
    2021 RT Limited
    2021 Spyder RT Liminted , Marsala Red in Black
    Active Member rays hell's Avatar
    Hiram Ga.
    I put mine back on my 16 F3T (to sell) and moved my bypass with 2 baffles, one on either end, to my 21 F3T.
    Will be storing that cat as well.
    Monique,
    2016 F3t pearl white
    Ultimate driver back rest
    12v power outlet for batt. tender
    Doc Humphries' vibration damper
    factory floorboards
    added topcase
    Active Member robtdonna's Avatar
    Jul 2014
    Ellijay, Georgia, United States
    Hey Ray. A 21 eh. Good on you. Did you wear Monique out?
    Current: "Scarlett", 2017 Can Am F3-T, SE6, Intense Red Pearl.
    BRP heated grips, DIY brake light strip and turn signal strips, Chrome/LED brake light tag frame, SpyderPops bumpskid, Baja Ron swaybar and billet links, Lamonster Third Peg, BRP Adjustable Passenger Backrest, SpyderPops Missing Belt Guard, ShowChrome oversize brake pedal, TricLED foglights.
    Previous: "Synthia", 2014 Can Am Spyder RT, SM6, Pearl White.
    Linden, CA
    There are some states that require a SAFETY & SMOG INSPECTION every year and that is the first thing they look for. KEEP IT.
    Hiram Ga.
    Not really, 58k miles of smiles,
    She still runs like a champ, just thought I would upgrade before the prices go beyond the moon, and before I retire.
    Retired, no work, no worries, and you guessed it no money.
    I'll be selling Monique so if you know of anyone looking....
    Monique,
    factory floorboards
    added topcase
    Apr 2015
    Oneonta, NY
    I was told by a Spyder Tech. that those are not actual catalytic converters but just a "pre-muffler". I saw a photo of one that was cut opened and there were just tubes inside. No cat converter material. They are relatively heavy as are stock mufflers. I don't remember where I saw the cut away photo but this is what I was told. Take it for what it is.
    2016 F3 T , Fabricated adjustable brake rod Intense Pearl Red
    Dec 2013
    Quote Originally Posted by BanditoRS View Post
    Dunno about that Spyder Tech, nor about your 2016 F3 T Bandito, but the Catalytic Converter or pre-muffler or whatever you want to call it that came off my 2013 RT was VERY DEFINITELY a catalytic converter with a catalytic honeycomb inside one of those tubes contained inside the box. Admittedly, it's a very small amount of catalytic honeycomb; but still, it's there so it does sorta qualify as being a cat converter, despite the very small amount of converting it might do!! .
    IIRC, there was only about 1.5" or so of honeycomb material filling the inside of the middle one of those 2" dia 'just tubes' contained in the cat converter box - the rest of the box and all the baffles/restrictions on free-flowing exhaust etc are simply there to create sufficient/excessive exhaust back-pressure so that the trapped & choked exhaust gasses will heat up that catalytic honeycomb to the something well over 600°C that's necessary for them to effectively do anything 'worthwhile'!! . There again, there's such a tiny amount of catalyst material in there that for all the excess back-pressure & excessive heat produced, the 'worthwhile' bit in that previous sentence is questionable, as the tiny amount of catalyst contained will only be capable of 'converting' about 2/5ths of 5/8ths of s**; - altho that too is really not such a biggie, cos most (any large engined Boss Hoss or similar bikes possibly excluded ) modern 4 stroke EFI motorcycle engines are small enough & (can be/should be??) tuned well enough that they produce very little in the way of harmful emissions anyway - there's quite a few 'experts' who argue that the harmful by-products resulting from creating & eventually disposing of the cat converters installed on modern motorcycles far exceeds anything they may clean out of the exhaust they produce during their working life; but hey, they're ICE's that aren't electric, therefore they must be harmful!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Mar 2015
    Tacoma WA.
    Did deleting the cat add any kind of performance? I know it "adds" sound!
    2017 F3-S Daytona , Yellow and black
