Results 1 to 25 of 26
    May 2022
    CA
    Thumbs down RAM Mounts - destroyed my iPhone! Any ideas on mounts that won't fail?
    Bought a RAM Mount for my iPhone and I've experienced my phone flying out of the mount when riding at high speeds or in areas with high wind...
    The first day I installed it and was riding from LA to SF my phone flew out and hit me but luckily both my headphone cable and the little underwear piece held onto each other and I was able to pull over and remount my phone.
    Yesterday was another story unfortunately... I was merging on to an open lane in the freeway and hit the throttle for a good 8 seconds when I noticed my music wasn't playing anymore and my phone was missing from my RAM mount. I looked and looked and eventually went back home to use Find My iPhone to locate it on the freeway... went back to find it destroyed...
    My review of RAM Mounts -> 1/5
    It seems like they prioritized the ability to "stretch" the mount out to fit a wide variety of phones rather than making sure the phones are secure... which makes no sense since that's the entire reason for buying a mount to begin with.
    Do you have a suggestion for a mount that fits an F3 and doesn't fail against the wind?
    EDIT: RAM X MOUNT
    Last edited by Jibrilll; 06-24-2022 at 01:17 PM. Reason: Briefly stated question in the title. ;-)
    Clinton, MS
    Contact Motorcycle Dave and get a Tackform phone holder. Pretty easy in and out but when "in" I think I could almost lift my RTL with the phone.
    https://www.spyderlovers.com/forums/...Tackform-mount
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    I use an SP Mount, with a remote charger, this keeps your phone safe.
    you need a special case and a dampener for an iphone, I drilled a hole in a bolt that holds the handlebars, and tapped a thread in it, been holding for over 4000 kms now, and still no movement at all
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Aug 2019
    Stoughton, WI
    Which RAM mount? I have both the Tackform and RAM Quick Grip XL. Neither will lose a phone under normal circumstances, but I'd likely trust the Quick Grip in severe conditions.
    2022 RT Sea To Sky
    Dec 2015
    Oakley Utah
    RAM is a system to which any number of mounts will attach (including GPS, USB chargers, cameras, etc).
    Which mount are you criticizing exactly? ?
    2014 RTL Platinum
    May 2022
    CA
    It's the X Mount - I've updated on my thread... this is one of two mounts (the other wasn't a ram mount) that the bike shop had in stock the day I bought my bike.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Jibrilll View Post
    Do you use the elastic web piece over the phone once it's in the grips?
    2014 RTL Platinum
    Bossier LoUiSiAna
    Sorry to hear. With the rough roads we have here in a pocket(frunk if need charging) is really the better option. High speeds also not considered gonna hit pot hole -roadkill -something(drunks)
    PA
    I agree with Edmat. I have it mounted on both spyder and snowmobile. Let’s just say my snowmobile experience is I mountain riding pretty hard. I lost it once and the sled rolled 85 feet down the side of the mountain. Probably rolled 30 times. Not uncommon in pure powder and no damage. That’s what those sleds are made for. I have an iPod touch mounted to the tackform and it was still on there at the bottom. Done 70 mph plus on spyder and you really have to work at it to get the phone out of mount. Ram mount balls and arms are bulletproof. Your x mount, I wouldn’t trust with a cheap phone even with the spyder web. Sorry to hear about your incident but from my experiences go tackform. Get it from motorcycle Dave!
    Active Member kroache's Avatar
    Mar 2021
    Caledon, Ontario
    I like the Tackform option as well. Hard to imagine my phone falling out of this thing. I have one on my RTL as well as my Indian Roadmaster and no issues after many miles.
    Cheers
    Kevin
    2020 RT Limited - Chalk Metallic Dark
    Nov 2016
    Upstate NY
    I use the RAM quick grip. The tackform does not work with my phone because it presses on the power button. If your power button is on the side of your phone, I highly recommend the quick grip or quick grip xl(if your phone is large)
    Mar 2019
    Pennsylvania
    I have had many of the holders listed. Last year I destroy the camera in my IPhone 11 due to vibration of the handlebars. I highly recommend the QuadLock system with the anti-vibration dampener. I got the version with a ram ball and I mount it to a Ram Claw mount on the handlebar. Their are other combinations to choose from.
    Last edited by Peter Aawen; 06-28-2022 at 05:26 PM. Reason: care as in?? - camera ;-)
    Harrington, Australia
    My review of “RAM Mounts” -> 5/5. The Quick Grip has not failed me once in 10 years.
    HeliBars Handlebars
    Kenda Kanine rear.
    Active Member Garf's Avatar
    Oct 2017
    Ortonville, Michigan
    I've been using the Ram X grip with the elastic tether for 10 years, both
    on my RT-L and my previous BMW. Never had a concern for the phone
    falling out. Thousands of freeway miles and Michigans lousy roads.
    Gary
    2017 RTL Asphalt Gray Metalic
    1987 BMW K75s
    Jun 2015
    Ritzville, Wa
    I experienced the exact same results with my Ram X mount. Lost the same phone twice. I was able to find it again, thankfully, but each time required a mail in to have the screen replaced at about a one fifty each. Ended up costing me more then I paid for the phone. I finally ditched the X mount and went with the QuadLock. Have had zero issues since.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    I had a similar issue that you did. I went with the Quad Lock system with the wireless charging. I have had the Quad Lock for 2 years and really like it. Take a look.
    https://www.quadlockcase.com/
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Mar 2021
    Maryland
    I can testify for the tackform, have it mounted landscape on a centermount from Dave with USB-C charging run to it. I was run off of the road and hit the curb hard enough to be tossed over the handlebars and into the curb.
    Phone was still in the tackform and I called for help on my Sena 50R.
    2020 F3 SE6
    2020 F3 , Black
    Oct 2021
    Wichita, KS
    LaMonster Phone Phang. Looks to be exactly the same as the Tackform. These holders are solid as a rock.
    Peter Pan has struck again!
    Linden, CA
    Default Time for a change for the better
    Hi Everyone here looking at this thread, it's time to make that change,
    Do you want to trust your $$$ Thousand dollar phone $$$ to a chunk of plastic
    clamped on your handlebars or center bolts... ?
    You know that after a while that plastic mount will wear out, the corners of the locking device will round off, and then you can kiss your phone good-bye!
    There is only one out there that will never do that and I have them in stock to fit any bike car or Spyder...
    All Our mounts are made of billet aluminum, then machined and anodized, and/or powder coated. The clamp uses stainless steel springs and the clamp is coated with rubber.
    AND !!! it will NOT push your buttons.
    Call me today and get your TackForm mount and never worry about losing your phone again!
    209-887-3283
    Last edited by Peter Aawen; 07-30-2022 at 11:28 PM. Reason: Removed spurious orphan cmds... & moved post title into text - many ONLY see Thread Titles! %-/
    Aug 2013
    SF Bay Area
    I’ve never used anything else but the RAM X-grip and never lost a phone. The thing is I don’t mount to the bars, I mount to the dash. Too much vibration mounting anything to the bars. Damages the device and can vibrate loose.
    2021 F3 Ltd , Magna Red
    Member Waldo1122's Avatar
    Sep 2021
    North Carolina
    RAM makes the WORST mounts on the market, they spend every dime they make on marketing instead of R&D. You'll notice that 90% of people that have a RAM mount don't have their phone inside the mount because it has already flown off into the wind. Buy Quadlock and never deal with garbage mounts again.
    Blue 2019 Spyder F3-S
    Aug 2019
    Stoughton, WI
    I have two Tackforms on my F3S and the RAM Quick Grip on my little Benelli. I put neoprene strips on the Quick Grip to dampen it. Both work well.
    2022 RT Sea To Sky
    Aug 2013
    SF Bay Area
    Quote Originally Posted by Waldo1122 View Post
    I’ve used RAM for years and no problems. They wouldn’t be in business if they made products that didn’t work.
    Couldn’t agree more, Flamewinger. I have not had an issue with RAM for either connectors or clamps in 20 years.
    HeliBars Handlebars
    Kenda Kanine rear.
    Vermont
    EDIT: RAM X MOUNT
    Jibrill,
    I just bought the same thing ( Ram- X mount) from Lamonster Garage. I have a Trac phone( LG phone).
    I have my Ram X-Mount installed below the ignition switch, ( between the handlebars above the glove box).
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
Tags for this Thread
