Results 1 to 12 of 12
    Apr 2012
    Greenville, SC
    Default Which direction to undo front sprocket bolt?
    I even bought the shop manual and it does not say. I have tried the normal counter-clockwise direction and it does not want to budge. Before I try a little harder, I want to be sure that this isn't a left-hand threaded bolt? So counter-clockwise or clockwise to get this darn thing loose?
    Also, I have 18,000 miles on mine, there's no hint at all of red rust. Maybe I should just leave well enough alone? I did get the Loctite Moly and was going to lube it up, but maybe I don't need to at this point?
    Thanks!
    Northern Kalifornia
    Without knowing what spyder you have, you are correct, leave it alone.
    Feb 2019
    Portland, Oregon
    It's a right hand thread and I would examine it, clean the splines and cover the them real good with the Moly Paste. Torque to 110 ft/lbs. I did not like the looks of the lube BRP used - it appeared to be just a white lithium grease. Maybe that's the cause of the failures?
    Apr 2012
    Greenville, SC
    Sorry, it's a 2017 Spyder RT. I have 18,000 miles on it. There's not a trace of red dust to be found anywhere.
    On the one hand I feel like taking it off and cleaning it and putting in new moly paste, but on the other hand, if there's no red dust whatsoever maybe it's best to just not F with it at this point.
    Northern Kalifornia
    Quote Originally Posted by jfischer View Post
    Yep, keep it clean and keep an eye on it. Much luck to you with that issue.
    " Maybe that's the cause of the failures " .... That's the exact question I raised a long time ago ..... The 2015 F-3 started Started having higher than normal rates of FAILURE at about 18,000 mi..... the front pulley / sprocket system has been used since 08 !!!! .... So WHY are they starting to FAIL ????? ...... Metalurgy, Paste, assembly, I doubt we will ever get answers .... at least not from BRP .......... JMHO .... Mike
    Clinton, MS
    Thanks!
    Keep checking on it every few thousand miles, but, if it does not exhibit the red rust signs don't touch it. Why cause problems where there are none. At this point I believe that minor sighting of rust staining does not mean that you are facing imminent failure of the splines.
    Jun 2011
    Near Lexington, NC
    Is your '17 RT included in the front sprocket recall? If so, hang on till dealers get replacements.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Mar 2019
    NEBRASKA
    My 14 has a lil dust but 41000 miles ....so if it's the same sprocket from 08' --whaaaats the difference now?
    2012 RTL 14 RTS , Pearl White @ Pearl White
    Linden, CA
    Thanks!
    Lefty loosie righty tighty
    Apr 2022
    GA
    If it ain't broke.....
    2017 SPYDER RT LIMITED
    Apr 2012
    Greenville, SC
    Yeah but I don't know if it's broke unless I pull it off and inspect it . Seeing as how I had no trace of red dust at all, I have not fooled wth it yet.
