Results 1 to 22 of 22
    Active Member Beanz1's Avatar
    Aug 2021
    Louisville,KY.
    Default Who has the Forward/Reverse Jockey Shifter on your Ryker?
    I added the Jockey Shifter and I really enjoy having it on my Ryker. I just couldn't get comfortable using my foot to get the ryker in reverse.
    280719589_5084915368253831_6522937508688221263_n.jpg.....286539750_5159242660821101_5546302732563072331_n.jpg
    U.S.Marine Corps
    Vietnam-Veteran 68/69
    Active Member MonPaul's Avatar
    Feb 2019
    Central WI
    Looks great! What panels did you have to take off? I just got my Ryker and I'm not looking forward to taking any off.
    Active Member sKiZo's Avatar
    Mar 2021
    Michigan
    You need to remove the lower cover to access the mounting point for the new linkage. Three pop pins and carefully unclip the top where it locks into the upper panels. Couple good videos on the install. Only complaint I'd have - I tucked it in tight to keep it from rattling on idle, and that was causing a wear spot where the shifter rubbed against the air cleaner. A rubber sleeve fixed that.
    I love mine ...
    Half a million miles, and I ain't dead yet.
    See my album at https://www.spyderlovers.com/forums/...p?albumid=5190
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    Originally, I used a kick-start which allowed the wife to be able to at least reach the shifter. But when this shifter came out, it was a much more viable option. The wife is happy now.
    2021 RT Base - Petrol Blue
    Active Member ziggy's Avatar
    Apr 2021
    North Carolina
    Got it on Quasimoto, I like it.
    If I had a Ryker, I would have one of those cool shifters.
    Mar 2021
    Michigan
    The perfect shift ball, courtesy of a dumpster dive at the neighborhood tractor repair came up with a transfer case knob from a Massive Furgeson ... ;-}
    Aug 2021
    Louisville,KY.
    Quote Originally Posted by sKiZo View Post
    I wish yours was mine!
    U.S.Marine Corps
    May 2022
    CA
    I have the TREX jockey shifter…… I love it…… makes shifting a breeze...... not to mention how easy it is to find “neutral” should you need it.
    Active Member strictlyred's Avatar
    Mar 2012
    Canada
    Where did you get that with the colour shifter?
    Aug 2021
    Louisville,KY.
    Quote Originally Posted by strictlyred View Post
    I answer your PM, where I got it.
    U.S.Marine Corps
    Mar 2012
    Canada
    I purchased one, had it installed but now want a different ball…
    What would I ask for when searching for this?
    Is the fit generic or do they come in different sizes (the threading)?
    And how do I remove the original?
    Aug 2021
    Louisville,KY.
    I had to buy a 5/8 nut and sit it inside the knob to make it fit the shifter stick. Here are pictuers of the 8 ball I had to improvise to make it work on the shifter stick. You know how Marines will find a way to make something work if it dosen't. lol PS, I hope this help you, and use some loctite super glue to keep the studs from backing out.
    305954146_5418834541528577_6330351452793970370_n.jpg...305935808_5418834811528550_2386510182562735530_n.jpg
    U.S.Marine Corps
    Aug 2021
    Louisville,KY.
    picture on the 8 ball knob....Delete
    U.S.Marine Corps
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Do you have a way to find out what thread is used on the end of the shaft? Once you know the thread, you can pick any knob you want.
    Aug 2021
    Louisville,KY.
    Quote Originally Posted by Markubis View Post
    My gearshifter has a 5/8th threaded stud to fit into the 5/8th nut.
    U.S.Marine Corps
    Jan 2018
    NH
    You mean 5/16 inch or 3/8 inch thread? There's no such thing as 5/8....unless you're talking about the size wrench you used.
    Also, a lot of the knobs have metric threads....I believe it's 8mm
    Dec 2013
    You sure?? These guys think there is:
    https://www.aptp.com/technical/stand...d-pitch-chart/
    And these:
    https://www.packerfastener.com/techn.../standard.html
    And there's this:
    https://www.google.com/search?q=5%2F8+thread
    Mind you, if someone says it's a "5/8th nut", that would normally be referring to the wrench size.... but still, it certainly looks like there is such a thing as "5/8th thread" ....
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Aug 2021
    Louisville,KY.
    And these:
    And there's this:
    Thanks for the correction, I made it work for me look at the pictures I post that might help.
    U.S.Marine Corps
    Aug 2021
    Louisville,KY.
    U.S.Marine Corps
    Jan 2018
    NH
    Looks like either a 5/16 or 3/8 to me. You can measure the width to be sure. The pitch for the 5/16 is either 18 or 24 and a 3/8 will have either 16 or 24. You can check pitch by laying a tape measure along the threads and counting how many threads are in the length of one inch.
    I'm positive that a 5/8 inch diameter rod was not used for the jockey shifter. :-)
    Last edited by Peter Aawen; 09-09-2022 at 06:38 AM. Reason: Merged 2 posts by this poster & made in the same minute.... :-/
    Aug 2021
    Louisville,KY.
    I used the short rod to see if it was the same size as the bike shifter rod to fit the nut.
    305956662_5421222131289818_3681886150124201410_n.jpg....306101438_5423441794401185_82366435683314504_n.jpg
    U.S.Marine Corps
