Results 1 to 12 of 12
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Default Hard time opening side bags on 2020 RT LTD - anyone else?
    Anyone else have a hard time opening the side bags on the 2020 RT LTD? I think i actually have one side that is either broken or the latch has come unhooked. The other side you have to pound on with the latch open to get it to pop open. Seems like they may be misaligned or something.
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Oct 2020
    Fresno, Texas
    Hi,
    If you're sitting on my bike, I have a hard time opening the saddle bag on the left. I've learned to place pressure against the saddle bag with my thigh while simultaneously pulling on the latch and it releases. I just remind myself not to pull too hard and break the plastic latch! Not an issue with the right side saddle bag. It operates perfectly.
    2020 Spyder RT Limited
    Deep Marsala Red
    Katy, Texas
    Quote Originally Posted by FINFAN3DP View Post
    The saddlebag latches can be adjusted for easy opening.
    Dec 2013
    There are a few threads here about this sorta difficulty &/or broken latches, and a couple more discussing how to adjust the latches to make opening sticking side bags/panniers easier/possible - IIRC, that's including at least one pretty good thread in which a post from cptjim of Squared Away fame is quite detailed . Sorry I can't search them out for you atm, but I'm mobile & on my phone, so it'd take more concentration & effort than I have available/can spare right now! . Over to you!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Aug 2020
    Georgia
    Push in at the top with one hand while pulling on the lever with the other. Be careful to not pull too hard on the lever as it is plastic and it will break (DAMHIK). Sometimes it takes a couple of tugs and pushes. They are not the easiest saddlebags to release and this is mostly due to the way the cable is routed near the lever: It has to make a hard turn and the wire inside the cable binds on the metal ferrule on the end of the cable. The cable is just like a throttle or clutch cable but lubing it up won't help because of the way it binds where the steel wire exits the cable sheath. Poor design IMHO.
    Sold: 2020RT base with numerous improvements and farkles
    Previous 2 wheels: 3 BMWs, 1 Honda, 1 Yamaha and 1 Husqvarna
    Danbury Connecticut
    I found this thread to be very helpful. I think this is the post Peter Aawen is referencing.
    https://www.spyderlovers.com/forums/...=1#post1541298
    IBA #47122
    2020 RT Limited Asphalt Grey
    Active Member Pooch's Avatar
    Feb 2018
    Texas Hill Country
    My '21 RTL is just opposite... the left bag will pop open as I drive. To avoid this I make sure it is locked with the key.
    Never any problems getting either bag to open.
    2021 RT Ltd, Marsala Red/Black, Dark
    New course heading Mr Sulu: 2nd star to the right and straight on til morning...
    Active Member BUZZARD II's Avatar
    Dec 2016
    NoVA
    I have a '16 RT and have found that cleaning and lubing the latches a couple of times a year works. It depends on accumulated road dust.
    Jun 2018
    HAYMARKET,VA
    Well, i tried everything. Nothing worked. So I dropped it off at the dealership today. While there i opened two on the floor, WOW they operate perfectly, which mine has never done. Hopefully they fix it like those were, because I would be thrilled!
    Baja Ron Sway Bar
    Key Cover from Ebay
    ... and it should be done " under warranty " ..... It should have been checked before delivery .... jmho ... good luck .... Mike
    Aug 2012
    Central Ohio
    THANKS!! Can’t believe I struggled with this for two years and it was this easy to adjust.
    Apr 2013
    Hartsville, S.C.
    This is a "known issue". BRP has issued some type of bulletin that addresses the fix for the dealers.
    2021 RT Limited Asphalt Gray
    Halo Skid
    Driver's backrest
    2" riser w/ F3 standard handlebars
    F4 vented 25" windshield
