Results 1 to 10 of 10
    Active Member brerrabbit's Avatar
    Jan 2015
    Colorado
    Default Spyder shifted from reverse to 1st while backing up.
    2018 Spyder RT - My wife's Spyder shifted from reverse to 1st while she was backing out of garage. She got it stopped before hitting anything but was wondering if anyone had any ideas concerning this.
    =bob=
    2018 RTL--------------------------------2018 RTL
    Champagne Metallic-------------------Oxford Blue
    Lamonster Pegs------------------------Lamonster Pegs
    Motorcycle Dave Gel seat inserts----Motorcycle Dave Gel seat inserts
    Big Bike Parts Backrests--------------Big Bike Parts Backrests
    Magic Mirror mounts------------------Magic Mirror mounts
    Tri-Axis Handlebar---------------------Tri-Axis Handlebar
    KurYakyn Grips-------------------------Foam Grips
    2018 Limited , Champagne Metallic
    Have you tried to replicate the incident on flat, safe ground? Put the Spyder in Reverse, crack the throttle a bit to move the Spyder backward, with your R foot nowhere near the brake pedal, push the shift lever to upshift. If the Spyder shifts to 1st you have a problem with the brake safety interlock.
    Jan 2015
    Colorado
    I have tried to replicate the incident to no avail. I've tried with no brake, partial brake, just touching the brake etc. all while barely moving and at different speeds, again while accelerating and decelerating and cannot get it to happen again.
    I am inclined to question the handlebar control as we have had the brake release problem come and go. On our other 2018 we had the handlebar control replaced in the first year we had it due to the brake release issue and failure to shift into and out of reverse. These were intermittent as well. I still have the brake release issue but very infrequently now. Her bike is getting more often with the brake release issue, it happened again yesterday while on a ride following the shifting issue mentioned above. Based on the responses to this post, it doesn't appear to be a common thing.
    =bob=
    Since I've no experience with MY '18 RTs I've exhausted my diagnostic ability. You may have a problem with that left handlebar switch assembly. Ouch!
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    I am NOT saying this IS the case, but I have seen this happen on several occasions, including myself.
    Rider, is looking at the R Button & Shifter, press buttons HEAR the CLUNK, look behind, and hit the THROTTLE.
    Bike goes FORWARD!
    Why? Because the Bike was NEVER in Reverse.
    Hearing the CLUNK is not a guarantee the Bike is in Reverse. You are only in Reverse IF/WHEN that light comes on.
    Yeah I know one would think Not Me, but ones realization of a situation does not always align with REALITY.
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Harrington, Australia
    Quote Originally Posted by PaladinLV View Post
    Bike goes FORWARD!
    AJ
    Yes, I have done exactly that, AJ……only once, mind you
    HeliBars Handlebars
    Kenda Kanine rear.
    Jan 2015
    Colorado
    I have been able to replicate the incident. While backing slowly, slight pressure on brake pedal but not applying the brake and bumping the shifter to shift up, the bike will shift and lurch forward.
    Feb 2015
    Las Vegas
    Quote Originally Posted by brerrabbit View Post
    THAT is normal behavior.
    All that is required is the bike senses that the Brake Micro switch was engaged which occurs PRIOR to actual brake pressure.
    AJ
    2014 RT-S
    2014 RT/S , Black
    That's the cause, right there. As Paladin explains, you only have to barely push on the brake pedal to cause the brake switch to close. That allows for the shift to first from reverse. Have someone watch your brake light as you gently push on the brake pedal. As soon as the brake light comes on make note of just how little you pushed the pedal. The brake light signal also feeds the ECM which then controls the TCM.
    The best solution is keep your foot off the brake until you need to stop. Having your foot on the brake while driving will cause a limp home error. Even just touching the brake pedal with the side of your foot can trip the brake switch.
    That's the cause, right there...The best solution is keep your foot off the brake until you need to stop...Even just touching the brake pedal with the side of your foot can trip the brake switch.
    Exactly! If I'm cruising along with the CC on and want to pause it I just tap the brake pedal with the side of my right foot.
Tags for this Thread
