Results 1 to 10 of 10
    Mar 2014
    Midlothian, Texas
    Default Saddle bag won't open
    2015 RTL. Having trouble opening the saddle bag even while pushing in. Is there an emergency way to open a saddle bag?
    Quote Originally Posted by dbaucum View Post
    I have a 14 and had the same issue .... You can see all the parts involved @ can am oem parts.com .... look for the Fiche' " Luggages " the pic is in the upper middle of the fiche Part # 135, is has the adjustment cable attached .... starting under the trunk lid that panel had to come off .... it's tricky to get off ..... Maybe someone has an easier way ..... good luck .... Mike
    Feb 2013
    Edinburg, TX
    Pushing in? When mine is cantankerous, I hold the release lever all the way out while giving the side of the bag a sharp rap with the palm & heel of my other hand, all the way up high where the latches are. Then, when finally open, lubricate the latches.
    NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
    Retained the old mirrors with TricLed Signals
    General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
    Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
    Riken Raptor HR.........rear tire (at 114,200 miles)
    Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
    Gear Brake Decelerometer Module
    OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
    BajaRon Anti-sway Bar
    Kumho ECSTA AST rear tire (at 14,200 miles)
    TricLed Turn Signals in Mirrors
    2015 Limited , Intense Red Pearl
    Oct 2021
    Wichita, KS
    There are a bunch of threads on this forum dedicated to adding an emergency pull cable to your saddlebag, frunk, or whatever. Search it. Heck you can even use heavy duty string of some sort. Of course you have to get it open in the first place but once you do and add the cable, you won't ever have to worry about it again.
    Peter Pan has struck again!
    Quote Originally Posted by FrogmanDave View Post
    I used to do Frunk and Seat cable re-leases as a Vendor ..... never heard, or seen one done for the side bags .... Mike
    Oct 2021
    Wichita, KS
    Fair enough. Apologies for the misinformation.
    Dave .... I don't think it was " mis-information " .... someone may have done this, I just haven't seen it yet ..... Mike
    Jul 2010
    Las Vegas, NV
    There is a way:
    Open trunk, and saddlebag that will open. The two screws that hold the rear panel are hidden by the saddlebag lid. Remove them, and the 4 across the top of the trunk. The rear panel is now held by the saddlebag that is stuck. Gently bend the panel on the open saddlebag side until it is clear. You will see 2 cable adjusters. On the stuck side, loosen the jam nut, turn the tightening nut to take out the slack. Pull lever, open saddlebag. Remove the two screws under the bag lid, remove the panel, finish a proper cable adjustment, tighten the lock nut. Put back together. Call if you get stuck. Joe
    Joe Meyer
    Jul 2010
    Las Vegas, NV
    Joe Meyer
    Mar 2014
    Midlothian, Texas
    Great info. Thanks
