Results 1 to 10 of 10
    May 2022
    Virginia
    Default Ryker 600 - will the speed/RPM be too high for a regular 75mph commute?
    New member. Just purchased a 13 St-L. My sister is looking to purchase a ryker 600 but lives in Texas. Her question to me was with the speed limit being 75 for most of her work commute, would the 600 be worn out prematurely from running high rpms/speed. So basically should she get a 900 or is the 600 sufficient? Thanks for any help.
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    If bought new, first few hundred miles, should be driven with various RPM's, for proper break in, I don't think 600 or 900 would be an issue, 75 mph cruisin speed won't harm any motor, overhere in the Netherlands we have cars with a 750cc 3cylinder engine, and they cruise interstate speeds around 130 Kmh, with no problem at all (130kmh is just round the 80ish miles mark)
    So I see no problem for the ryker wearing out prematurely, proper maintenance goes a long way
    How long does the commute take? Long enough to get everything in the right temperature range? I drive an F3 myself, and it takes just about 25/30 minutes to get everything warmed up properly.
    Furthermore, the drivebelt on a ryker, has to be changed every 12000 miles or so
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Sep 2016
    Chillicothe, Oh.
    Quote Originally Posted by Venomous View Post
    The 900 may feel more relaxed at that speed, but it will not harm the 600.
    2015 RT , Black
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Rotax is very well built, but if, due to the CVT, high speed cruising RPMs are 7,000 versus 4,500, the Rotax is going to turn the same total number of revolutions in 6 years as a motor turning 4500 RPMs will turn in 10 years. Or, in terms of mileage, 60,000 miles versus 100,000 miles.
    As a comparison, my 2014 Honda CB1100 was only ~5,000 RPMs (~60% red-line) at 100 MPH (6th gear), whereas the Ryker is at least 7,600 RPMs.
    My 2022 Triumph Street Twin, 900cc OHC, 4 valves per cylinder is 4,200 RPMs at 80 and 5,200 RPMs at 100
    For legal cruising speeds, such as Interstate 15 in Utah, 75-80 MPH Ryker RPMs are 6,500-7,000.
    The Ryker is a great roadster/hooligan/hot rod, but at 80 MPH, it is very high RPMs.
    My 2020 did well on a 1105 mile 6 day trip, but higher RPM may be tiring for a regular long commute.
    Also, 33 MPG for the 900 was disappointing.
    Did not get much activity on this 600 thread
    https://www.spyderlovers.com/forums/...yker-600-stats
    I test rode a new (off the show room floor) 600 while the dealer was assembling my 900.
    I did not want to push a new motor, but it did 70 on the Las Vegas 215 belt way effortlessly.
    So, a top end of 90 quite likely.
    The advantage of the 900 is high speed passing and pulling a 6% grade
    600 or 900, it is a "great local machine" and is capable of long distances, just at higher RPMs.
    Last edited by Peter Aawen; 06-09-2022 at 04:55 PM. Reason: Removed duplicated paras ;-)
    Active Member ziggy's Avatar
    Apr 2021
    North Carolina
    No problem doing that speed on the 600. I do it quite often.
    I weigh 200lbs. too.
    May 2022
    Virginia
    Thanks for all the great information.
    Active Member Beanz1's Avatar
    Aug 2021
    Louisville,KY.
    My Brother and his wife are thinking about buying Ryker 600's, they both are retired from the USAF. He is 70 and she is 60 years old. He said it's not about speed for them they just want to enjoy riding together on their on Ryker's. Both have never owned two wheelers so they feel it would be easy to learn to ride an automatic three wheeler.
    U.S.Marine Corps
    Vietnam-Veteran 68/69
    Jun 2015
    Ritzville, Wa
    I don’t think the 600 would have any trouble handling interstate/freeway speeds. As Piratezz mentioned there is a break in period so you’re going to want to ride at various speeds/rpm’s. So I think either the 600 or 900 can handle that situation very well. Having said that, if the budget allows, I would opt for the 900 mainly due to it’s high end torque, for passing.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Quote Originally Posted by Beanz1 View Post
    Many, many folks here who have never been on a MTC prior had much better " learning " experiences .... because they were never on a Mtc. ..... good for them .... Mike
    The Ryker will probably sound LOUDER due to the higher rpms. That is the only annoying part that you have to worry about.
    The early Spyders had a very high rpm allowance. The did not wake up until they were above 5500 rpms. Only one blew up that I know about, and that person drove it extra hard and with a turbo system on it. Right Doc ???
    Rykers are slightly different, but they are built for today's speeds and drivers. Have not heard of a blown Ryker engine yet.
