Freddy ... welding was a thought - Sprocket and shaft being toast. I've seen the service bulletin reading 81 to 89 ft/lb for the bolt. I will phone the shop today and get a price on parts and labor. I will need to find the NEW belt tension specs also.
I will scare you with a price later. Thank you both for the info. Have a great day and be safe.
Reason: e' '. - e. ;-)
Well guys... I called the shop this morning - the sprocket is $173.39; the Shaft with seal is $397.29; The labor is 10 - 12 hours @ $105 per hour; plus any gaskets that are needed. Of course, the engine has to come out. Looking at just over $2200 plus.
The welder is starting to look better and better. I think Freddy you said to put a new sprocket on, then weld it on??? Have to look at all my options.
Reason: s' '. - s. ;-)
Ozzie Ozzie Ozzie
Reason: Fixed quote display
