Results 1 to 19 of 19
    Very Active Member Isopedella's Avatar
    Feb 2022
    New Zealand
    Default Where is the brake alarm beeper located?
    Where is the location of the brake alarm beeper, how do I locate it.
    Just want to tone it down a bit. Muffle it in some way I guess.
    Why on earth would I want that you may ask?
    Well. I like to store my SE6 F3 in neutral and dont find the need to report it to the all the immediate neighborhood within 100m.
    My neighbor and a mate of mine from 3 doors away was about to ring the Fire Service and report a possible smoke alarm sounding in my shed, turned up with his phone at the ready and puffing from sprinting over.
    Not for 1 moment looking for any advice on leaving it with the brake jammed on or off for long periods of time. Thats sorted thanks.
    Last edited by Isopedella; 04-18-2023 at 01:40 PM. Reason: Might be clearer about what it is you want to find?? ;-/
    Jun 2016
    Harrington, Australia
    Isopedella, sorry, but that’s a bit ambiguous. I leave my Spyder in neutral, but I DO leave the park brake on. If I want to move the Spyder, I turn the key, release the park brake, move it, and reapply the park brake…..all without starting the Spyder. Are you saying you want to leave the Spyder in neutral, and ALSO leave the park brake off?
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Feb 2022
    New Zealand
    Pete
    My seemingly ambiguous question is " Where is the location of the brake alarm, how do I locate it."
    Not for 1 moment looking for any advice on leaving it with the brake jammed of or off for long periods of time. Thats sorted thanks.
    Aug 2020
    Il
    Quote Originally Posted by Isopedella View Post
    I'd be curious about this too. I leave my Spyder parked in the garage with in neutral and the parking brake disengaged. Not sure if this is true or not but my Spyder mechanic said this can potentially save the life of the brakes, rotor or brake motor.
    21 Spyder base F3
    Pete
    ... sometimes the Simple solution is the wisest .... JMHO .... Mike
    Feb 2022
    New Zealand
    If you do know the location and or how to get to it I would be very interested.
    Bossier LoUiSiAna
    Maybe you can access the micro switch that feels the position of the park-brake motor cog wheel. Should be mid bike Rh when sitting on bike. (locate P brake cable & back track) However, no telling what other programs the computer might be running to check said brake & function * some posters have mentioned the switch failing, cables coming off the cog, & other various parking issues. The “siren” or "beeper" I believe is built-in as part of either ECU or dash.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Feb 2022
    New Zealand
    Im looking for the location of the beeper. Not looking to mess with any systems at all.
    Apr 2019
    Clinton, MS
    Have you tried obtaining a manual yet? Or, remove the dash face and track down the sound.
    Feb 2022
    New Zealand
    Yes I have, its on its way from the other side of the world...... apparently.
    I dont mind having to dig for it , remove stuff but would really appreciate the answer to my question of where it is located so I know where to dig.
    Seems to be a mystery so far. Blokes wanting to discuss things but not 1 addresses my question.
    Dec 2013
    Hmmm, I guess trying to stick it in a sock might help muffle it a bit?!?
    Sorry, too lame for a Monday arvo, right?!
    Anyhoo... my Spyder is a 2013 RT, but I think the loom will still be basically the same.... and I have a vague recollection of there being a beeper tucked into the bundle of wires etc behind the headlights; or more correctly, sorta behind & below the dash cluster.... but it has been a while since I had the dash completely out/off to expose all that stuff, & my forgettory about things that I don't really pay much attention too is getting to be waaayy too good! - Then again, there may well be more than one beeper too..... I can't say I really enjoyed having to get that far into the guts of the Spyder, but if it helps some... Still, it might be a good idea to see if you can find the beeper on one of the schematics, maybe cheapcycle parts or similar??
    Over to you... . Good Luck!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    Private message sent
    Beeper is mentioned 4 times in the manual but not its location. I've also checked the wiring diagram but can't see this marked as a separate unit (though I may have missed it). There is a module for the parking brake but as the beeper is also used for Throttle Body issues I don't think its going to be part of that. I wonder if its built into the dash unit because the only two feeds from the parking break switch go to the module and dash, though possibly that's just for the brake indicator light.
    Active Member Gedge's Avatar
    Jun 2020
    Claypool, In.
    The beeper's in the back side of the cluster, I put a piece of tape over mine to quiet it a bit.
    2019 F3 Limited, Black with Wrap My Spyder red racing stripes
    BajaRon sway bar
    La Monster LED headlights
    LED fog lights
    F4 Customs 21" tinted windshield
    Ultimate red trimmed seat/driver backrest
    Ram quick grip phone holder
    Cardo Packtalk Bold headsets
    2019 F3 limited , Black
    Active Member cravenfun's Avatar
    Oct 2021
    Old Forge, NY
    Quote Originally Posted by Gedge View Post
    2x . BRP puts beepers in the clusters of SkiDoo's and SeaDoos also.
    John
    "some suffer from insanity, I choose to enjoy it"
    '15 F3S SE6
    '01 FLHR
    Ski Doo 1200's
    Boats
    2015 F3S SE6 , Magnesium
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    [B]Where is the location of the brake alarm beeper, how do I locate it.
    It is in the dash main gauge cluster. I used an aluminized foil tape over the opening on mine... You have to pull the back of the cluster off to see it.... I did one layer at first and not much difference. Second layer toned it down by half... ;-)
    Chuck
    Feb 2022
    New Zealand
    Thank you Gentleman for the positive replies to the location of the device and the tips suggested.
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    Quote Originally Posted by hypurone View Post
    Can you point to a link where I can do this job myself ??
    Like the OP, I like to store my bike with the PB off and in neutral.
    Thanks in advance.
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
    Feb 2022
    New Zealand
    Found this. How to remove cluster.
    https://www.youtube.com/watch?v=WlzLAFT_EcA
    Feb 2022
    New Zealand
    Quote Originally Posted by PistonBlown View Post
    And thank you to you Sir. Extremely helpful indeed.
