Results 1 to 8 of 8
    Active Member Ryker900's Avatar
    Jan 2019
    Blacklick, Ohio
    Default Anyone tell me how to convert to a Right foot throttle?
    I would like to make a right foot throttle for my 2021 Spyder RTL to replace my hand throttle. My right hand has carpel tunnel. Could anyone tell me how to do that? I use to have a Ryker, now I have a SpyderRTL.
    2021 RTL , Red
    Oct 2015
    Lynden, WA
    Go to Facebook and look for Jake Jensen and Battle Born Spyders.
    Jake has a foot throttle.
    https://www.facebook.com/groups/157126601343192
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Very Active Member rjinaz86323's Avatar
    Mar 2021
    Arizona high country
    is your carpal tunnel not fixable? I had both of my. wrists fixed years ago. Should have done it sooner.
    . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2018 F3 Limited - Intense Red Pearl . . . . . . . . . . . . . . . . . . . . . . . . . . .
    Mar 2015
    forrest above Reno, Nv
    Quote Originally Posted by Haze View Post
    I believe that the shop ( Michaels of Reno ???) that converted his spyder to a foot throttle used a pedal assembly off a CanAm 4 wheeler.
    2014 RTS , Circuit Yellow
    Idaho
    The big challenge you'll be facing with this conversion is the fact the throttle is not mechanical, but electrical. You will have to come up with a way to turn the hand grip using your foot.
    2014 Copper RTS
    Mar 2015
    My friend Jake had his throttle converted to a left foot throttle using a foot pedal from a CanAm 4-wheeler. It works perfect............
    Now we need a comm system that that he can use. NO Touch is a must.
    Mar 2015
    Try a throttle assembly from a CanAm side by side ( a Turbo XP )
    Active Member robtdonna's Avatar
    Jul 2014
    Ellijay, Georgia, United States
    Easy surgery, cannot even see the scar, well worth doing, not only for ryding but for a multitude of other things.
    Current: "Scarlett", 2017 Can Am F3-T, SE6, Intense Red Pearl.
    BRP heated grips, DIY brake light strip and turn signal strips, Chrome/LED brake light tag frame, SpyderPops bumpskid, Baja Ron swaybar and billet links, Lamonster Third Peg, BRP Adjustable Passenger Backrest, SpyderPops Missing Belt Guard, ShowChrome oversize brake pedal, TricLED foglights.
    Previous: "Synthia", 2014 Can Am Spyder RT, SM6, Pearl White.
