Newbie Mistake - don't forget the rear tire when straddling pot-holes!
I learned a lesson on my ride to work yesterday. On a two wheeler, you learn to go around pot holes. In a car, I've always driven them so they pass under the middle of the car. We have a nice new assortment of potholes here in Columbus, so on my way in to work, a few popped up, and I steered right over the middle as if I was in a car. Forgot about that darn rear tire right in the middle, and I felt the hole. Actually, it was more of a crater. The only damage was to my ego! So I told myself "lesson learned," but when I went out at lunch I did the same thing. I hope that old habits aren't too hard to break!
I think someone on here said to aim your knee at what you are trying to miss.
Other than dodging them completely I have not found a good way over them. In my area if I try to put the pothole between the inside of a front tire and the rear wheel it wont fit and I usually catch a lip of the hole with the rear tire One nice thing about these lessons is we keep getting them until we learn
Reason: then = than ;-)
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
We have Moon Craters here in Toledo, 2.5 hours North of you. I try to aim the bike so the crater is between the paths of the front tire and the rear. That works about 10% of the time.
More often than not, there is a line of craters across the whole road, so that all three tires will bottom out!
Then I say to myself, "Self, detour this road in the future - find a different route".
That works for about 24 hours and too often I find myself back of Moon Crater Lane for more abuse.
Former Navy LT, Retired Chemical Dependency Therapist, Retired Widower, "Do, or do not, there is no try"... Jedi Master Yoda.
Proud member of AA, PGR, and a Navy Shellback!
I'm w/ Pegasus; if you can't avoid 'em safely, put 'em inside a front and outside the rear. The same goes for road-kill!
IMO, another good reason to have car tires.
Reason: additional comment
2020 Spyder RT Limited; Deep Marsala/Chrome
Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
General Altimax RT43 215/60/R15 on factory rear
Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
Extra LED lighting and misc. to suit my needs/wants
Because we have THREE wheels, I learned a long time ago, if the hole / holes can't be avoided hit it with the rear tire .... the suspension and alignment will be much less affected by than either front wheel .... JMHO .... Mike
After you get in some miles you will know where to place the bike so you can miss most of the nasty stuff. Practice makes perfect.
Once you've jarred your spine hard enough to the point of tears in your eyes, you'll break that habit, trust me.
I try to imagine trying to put either my right or left foot over the pothole (or other debris). This usually results in the obstacle passing between the either front tire and the rear.
Then again, if the pothole is the size of Meteor Crater, no evasive maneuver will avoid it, and you'll just have to brace for impact, LOL.
SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
2016 Toyota Sienna SE - hers
2002 BMW 325i - his
1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
2018 Can-Am Spyder RT Limited - hers
2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
2011 Tao Tao 50 - whoevers bike is in the shop
2007 Reinell 186 FNS - the dog's
1995 Fleetwood Flair 27R - EVERYBODY'S !
Originally Posted by BLUEKNIGHT911
Because we have THREE wheels, I learned a long time ago, if the hole can't be avoided hit it with the rear tire .... the suspension and alignment will be much less affected by than either front wheel .... JMHO .... Mike
Living in the northeast, potholes are a fact of life and tend to come in groups that make missing them all impossible. As Mike said, do your best to minimize the front end impacts when straddling won't work. I flex my legs (partial stand) to prevent the spinal 'tap'.
I think there's about 16 inches of lateral clearance between the front & rear wheels... this would help to judge what you can clear (or not).
NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
Retained the old mirrors with TricLed Signals
General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
Riken Raptor HR.........rear tire (at 114,200 miles)
Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
Gear Brake Decelerometer Module
OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
BajaRon Anti-sway Bar
Kumho ECSTA AST rear tire (at 14,200 miles)
TricLed Turn Signals in Mirrors
Everyone here seems to be on the same page with this issue. RayBJ's advice is very good advice.
2014 RTL bought in 3/20 with only 6,000 mi.
Came with Garmin 660
Car tires in 5/20; Elka stage 2 front shocks in 10/21
