Results 1 to 25 of 25
    Apr 2022
    SC
    Default To grill or not to grill that is the question
    I've been looking at radiator grills for my 22 RTL Dark. What are the Pros and Cons? What brand do you prefer? I like the look of the Hypnotic Concepts in black, fits in with the Dark theme.
    Active Member Scotts8826's Avatar
    Jun 2014
    Kansas
    I installed grills after my trip across South Dakota.
    Oct 2020
    Vinton, IA
    I looked at aftermarket grilles for quite a while before noping out, here's why: they didn't darken the radiators and give a true blackout look, the (mesh) openings are similar in size to the factory and really won't stop any smaller bugs from plugging the radiator fins, and lastly, I would have to wash both sets of grilles and still have to blow bugs out of the radiator.
    So after the first riding season, I removed the entire frunk module, gently picked (w/a toothpick), the bugs out of the rads, blew'em out, then sprayed'em with a light coat of black laquer. I removed the factory grilles, stretched aluminum screen over them, painted' em black, and reinstalled everything. (note: I used scrap pcs of aluminum screen-door screen, it won't sag after a gentle brushing)
    Now I have a RTL w/a (somewhat sinister) blackout look..., and I can clean the grilles with a rag on long rides, or a soft fingernail brush & soapy rag on wash day.
    Hope this helps.
    2020 Spyder RT Limited; Deep Marsala/Chrome
    Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
    General Altimax RT43 215/60/R15 on factory rear
    Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
    Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
    Extra LED lighting and misc. to suit my needs/wants
    Sep 2020
    Middletown, NJ
    The after-market grills are very good at keeping leaves and stones off the radiator fins and clearing any debris easily. They will not prevent small bugs from passing through. They also enhance the look IMHO. I prefer the weaved grills, not the stamped grills for the style. Plus they match the upper vent hole grills.
    2020 RT base , Chalk White
    They work and make the appearance of the spyder up line from OEM.
    Keep the grill clean, and actually check the radiators once in a while. The bugs still get through, and you may be surprised at what does get through anyway.
    Apr 2022
    SC
    I’m not too worried about small bugs getting caught. Heck that’s dehydrated snacks. Mostly for trash getting caught.
    Active Member GreyGhost's Avatar
    Sep 2021
    North Texas
    The first trip I made on mine unfortunately took me down a portion of rural road that had just been resurfaced with what appeared to be recycled concrete..by the time I could react I was as close to the turnoff as I was if I turned around..bottom line, as I was removing the grasshoppers and other bugs I removed 3 pieces of the concrete..
    Installing Kott grills was my first addition to the Spyder..
    2021 RTL Chalk White (a paler shade of grey, of which there are 50)
    Dec 2015
    Oakley Utah
    Quote Originally Posted by spyderdave View Post
    Hope this helps.
    That's a great idea.
    2014 RTL Platinum
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    Quote Originally Posted by Scotts8826 View Post
    HOLY CRAP!!
    2014 RTL bought in 3/20 with only 6,000 mi.
    Came with Garmin 660
    Car tires in 5/20; Elka stage 2 front shocks in 10/21
    Oct 2021
    Wichita, KS
    Quote Originally Posted by redrazor View Post
    HOLY CRAP!!
    That is exactly what I thought. The worst I have ever seen! I can't imagine what his teeth looked like after riding through that
    Peter Pan has struck again!
    Nov 2012
    Pueblo Colorado
    Been thinking of applying to the western KS Ag Bureau for payment as a crop pest exterminator...Grasshopper.jpg
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Jan 2015
    southern WI
    My thought is that adding the secondary grills just creates another layer to clean...and with two layers of junk stuck, in my opinion that will slow down airflow even more. I do like the look of some of them, but for cleaning and cooling purposes I've opted out from buying them
    2021 RT Limited
    2016 RTS , Pearl White
    Jun 2021
    Bossier City, LA
    I have the KOTTS screens/ grills.
    I painted them black with a rattle can before the install. I haven't looked back!
    --Exco
    Active Member SkipH's Avatar
    Nov 2021
    Nevada
    Yes, the first thing I did on this 21 is paint the radiators with high temp flat black paint. That aluminum look made it look cheap to me.
    It required a lot of masking, the results was a better looking front end.The Kotts grill has already caught some butterflies.
    Looking at that bug infested front end reminded me of a trip from Vegas to Kingman,AZ back in the day. I had a Honda GL 1000 and the yellow butterflies were mating and the front of the bike was completely yellow including my black leather outfit. Got home and the wife took the hose to me.
    Adj removable backrest, KOTT radiator screens
    Double horn (118db), Lamonster mirror fix
    tender plug in, luggage liner/bags, FOBO 2
    Drinks2go cup holder, replaced the seat strut
    Garmin DriveSmart 71 GPS, Garmin BC 30 backup camera.
    White pulley, Pedal Commander
    Laminar Lip- looks fonky but works.
    J&M 2003 CB installed
    Home made belt guard
    7x12 enclosed trailer
    2021 RTL Dark Chalk Metallic
    Skip H.
    Active Member kroache's Avatar
    Mar 2021
    Caledon, Ontario
    I have these from Pierre over at Can Am Accessories https://www.canamspyderaccessories.c...s-2020-and-up/
    I like the finished look better than seeing the open radiators and I figure it will help protect from larger objects while travelling. I 'm pretty pleased with the look and the overall product quality.
    Cheers
    Kevin
    2020 RT Limited - Chalk Metallic Dark
    Mar 2020
    Martinez, CA
    Quote Originally Posted by Mazo EMS2 View Post
    Sep 2017
    INDIANA, USA
    Default Less to Clean
    I for one don't like the mess. You still have some trash to Clean. Do as You like. I will enjoy my time with 'wind therapy'. ......
    ENJOY YOUR LIFE WITH A SPYDER
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    I really hope you wore a full face helmet, or at least a 3/4 shell with a face shield.
    2021 RT Base - Petrol Blue
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    Love bug season is coming up in Florida!
    Dec 2013
    Quote Originally Posted by Fat Baxter View Post
    OWW!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Mar 2018
    mississippi
    What did your helmet look like!!!
    2015 Can Am Spyder RT Limited
    Magic Mirrors
    Short Antenna
    LaMonster Dual Power Plate
    LED Headlights
    LED Fog lights
    Vibration Damper
    Spyclops
    Spyclops II
    Utopia Back Rest
    Mar 2018
    mississippi
    Gotta love the LOVE BUGS
    Magic Mirrors
    Short Antenna
    LED Headlights
    LED Fog lights
    Vibration Damper
    Spyclops
    Spyclops II
    Utopia Back Rest
    Oct 2016
    Faribault, MN
    Photos please, let's see that front end up close Brother Dave, seems we like the same mods though I have the PPA Widows w same tires and everything....
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Aug 2018
    Piperton, TN
    I read somewhere that every year, 20 trillion bugs are killed on windshields each year. Has anyone noticed a decrease in the bug population? Makes you wonder exactly how many bugs are living on our earth at any given time.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by ollicat View Post
    Well, I was in the middle of counting them, but now I've forgotten where I was and have to start again. Crikey!
    2014 RTL Platinum
