Page 2 of 2 FirstFirst 12
Results 26 to 38 of 38
  1. #26
    Nov 2016
    Upstate NY
    Sounds like low battery.
  2. #27
    Jan 2022
    North Dakota
    or bad battery connections
    2021 RTL , Asphalt Gray
  3. #28
    May 2021
    Michigan
    Sounds like a dirty connection at the battery terminals or a discharged battery
    Fenton Michigan
    2015 Spyder RT-S SE6
    2021 Aluma 6810H Trailer
  4. #29
    Jan 2021
    Descanso, CA
    Thumbs up I concur -- start with the batterry
    As Turbine stated the Big Bike power is connected directly to the battery with two ring terminals. And with a 2015 RT the battery should have been replaced at least once. Arizona is usually a friendly climate for vehicle electronics but checking, cleaning and tightening terminals is a good start. And all the symptoms with the trailer disconnected really point to a battery problem.
    WRT service manual Search is your friend. You will be buying an electronic version because you can't afford a paper version (they're several $100s but I have a 2014 if you want to waste your money).
  5. #30
    Arizona
    Quote Originally Posted by BertRemington View Post
    OK, more input. The R3 relay (main accessories and engine), left side of the Frunk, often chatters when the key is turned to the ON position.
    I disconnected and reconnected the battery terminals. Then, when the key was "first" turned to the ON position, all panel lights lit up and gauges worked. The horn also worked.
    Then, when I pushed the start button, everything went dead (all lights and gauges off).
    I then turned the key OFF, waited a bit, and turned it back ON. Nothing! Dead! S**T!
    All this time I had a Battery Tender connected to the battery, showing a charging voltage of 13+.
    I disconnected the Battery Tender, battery voltage initially remained at 13+.
    I then turn the key to the ON position; same issue, no lights or gauges.
    I then checked the battery voltage (with the Tender still disconnected), and it show only 10.3 VDC. Hmm?
    As suggested above, maybe it is a battery issue.
    Maybe the temporary shorted wires in the trailer damaged one of more cells in the battery?
    Thanks to those who suggested the battery!
    Guess I will get a new battery and see if that solves the issue.
    I will repost when the new battery is in.
    PS: Who is a good source for Spyder batteries?
    Thanks again to everyone who commented, much appreciated.
    This is a great site.
  6. #31
    Feb 2022
    New Zealand
    There is a bunch of fuses and the battery in the front trunk.
    Its under the insert.
    4 push pins to remove on my F 3.
    I would check the battery terminals.
    Thats remove. Clean and ensure they are bright, not forgetting to do the same with battery terminals.
    Then refit.
    Just nipped up and not rocket arm torque.
    Then fit to a battery maintainer to fully charge the battery.
    There is also a bunch of fuses under the covers above the battery.
    Take your time.
    Inspect carefully.
    Visually and you could pick a cheap multi-meter and work through them.
  7. #32
    Clinton, MS
    Since you have never posted a battery voltage I would first check that. Sounds low or poor connection at some point.
    I see now that you did. Thought I had read them all but didn't make it to page 2. I think when you solve your low voltage problem you will have fixed the rest. Good luck.
  8. #33
    indpls in
    ed he did 10.3 please read the post
  9. #34
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    The spyders are notoriously hungry for electrical power, when you switch the ignition on, several systems kick in, they stay alive for just 30 minutes after you shut ignition off, so if you repeat this several times, without starting and running the bike, for atleast half an hour, your battery is drained, tender does not substitute, for loss of power, merely tops up, and that at a slow rate,
    You might try your car battery, hook up with good cables, no need for the car to run, I think that would solve the problem, when making new connection, use starwashers on the battery.
    When I read this thread, I don't think it's a fuse, but battery related...
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
  10. #35
    Arizona
    Quote Originally Posted by Piratezz View Post
    You are right about the battery being the possible culprit. Other folks suggested this also.
    After more battery checks, it was determined the battery was not holding a 12+ VDC charge, dropping to 10+ after the battery tender was disconnected. Apparently 10+ VDC is not sufficient to turn the electrical system on, and to start the Spyder.
    Hind sight being what it is, I should have done a load check on the battery sooner.
    Maybe the temporary trailer short damaged one of more of the battery cells?
    It is the original battery, thus its eventual failure may have just happened at this time.
    I have ordered a new battery.
    Thanks to all for your input.
    Much appreciated.
  11. #36
    Sep 2020
    Middletown, NJ
    30 SECONDS. Should not be enough to cause the battery to drain unless it's already toast.
    2020 RT base , Chalk White
  12. #37
    Quote Originally Posted by turbineman View Post
    That is the #1 key indicator the battery is shot. When the voltage drops below 10.5 the system shuts down, totally. The heavy draw from the starter will easily drag a shot battery down below 10.5 when you hit the start button.
  13. #38
    Jun 2015
    Hampton Roads, VA
    If utterly dead, I did see this happen before. Locate the two fuse boxes in the front trunk - if you have the insert unzip it. Pop off both caps. I forget which side has it, but there is a large 60Amp fuse in the charging circuit that blew on a friends bike when they shorted an LED strip to ground. At least at this point the battery is right there under the fuses (two screws) to clip a test light to (the ground) and test both sides of the fuses with the key on (one side always 12V, if the other side is NOT 12V pull fuse and check it. If I did it right here is a link my F3 shop manual so you can look at which fuse(s) say control the dash power, etc.:
    https://drive.google.com/file/d/1-80...ew?usp=sharing
