Results 1 to 3 of 3
    Active Member ARNIE R's Avatar
    Mar 2017
    Leesburg, VA
    Default How far up or down in size can I go from 165/55/15 tires?
    Having a difficult time searching online for new front tires. Seems either no one has them or never did.
    How far can I go either up or down with the 165 or 55 number and find something close?
    2014 ST-S Cognac
    2014 ST-S , OEM Yes Cognac
    Quote Originally Posted by ARNIE R View Post
    On your thread you have a 2014 Spyder STS .... so I feel the safe MAX size would be a 175/55-15 .... I once used a 185/50-15 on my 14 RT , however I bent the fender brackets and added washers to the mounting bolts ..... going smaller is not a problem ... the traction loss will be minimum...... JMHO .... Mike
    Mar 2017
    Leesburg, VA
    Thank you, Sir. I’ll check on that size a bit.
    2014 ST-S Cognac
