Results 1 to 18 of 18
    Active Member LisaT's Avatar
    Mar 2012
    MN
    Question What's the best Rear Tire for my 2015 RT Ltd?
    Since I know this is the best place to get a good answer.....here's my question.
    I need a rear tire and I am wondering what is the best one people are finding out there.
    Thanks in advance!!
    Lisa
    Jul 2010
    Las Vegas, NV
    With shortages and scarcity, black and round is good. The General, Yokohama, etc are in many threads. Type in the size, and see what is available. Then choose.
    Joe Meyer
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Lisa, there are already threads with different opinions
    Do you want "best" for
    Snow
    Ice
    Mud
    Rain
    Dry traction
    Durability/mileage
    https://www.spyderlovers.com/forums/...ire-on-your-RT
    Quote Originally Posted by SportsterDoc View Post
    Snow
    Ice
    Mud
    Rain
    Dry traction
    Durability/mileage
    Using that LINK .... the post was in 2017 Aug of ..... 2017 ... Mike
    Quote Originally Posted by LisaT View Post
    Thanks in advance!!
    Lisa
    Before you buy a tire .... find out who is going to do the changing .... It matters .... lots of dealers won't do it unless they use a KENDA tire .... and frankly they are JUNK! The Vredestein 205-60 or 65 - 15 is either #1 or #2 ( best ) ... also the new Michelin Cross Climate are highly recommended. However, they are all Auto tires and most dealers won't touch them ..... Mike
    INDIANA, USA
    Default Tires Tires and More
    Thanks in advance!!
    Lisa
    Who is going to do your Tires? As most Spyder Dealers will only install the OEM TIRES. IF you have someone else that will install the tires then you will have other options.
    Just let us know, so we can help you out with other tires.
    ENJOY YOUR LIFE WITH A SPYDER
    Sep 2020
    Middletown, NJ
    The General Altimax RT43 is a good mild weather tire with long tread life.
    The Vredestein Quattro is the way to go for colder/wetter conditions and better traction with a small sacrifice in tread life.
    (Based purely on my personal experience)
    Many other tires are out there that fit and I'm sure someone will offer those as options but ANY car tire will be better than OEM.
    2020 RT base , Chalk White
    Quote Originally Posted by RayBJ View Post
    the Vredestein'\s cold weather abilities is certainly a plus ..... however, it's regular temp. ratings are at the top of any tire we can use ..... Mike
    Clinton, MS
    The correct link for tire info is https://www.spyderlovers.com/forums/...Spyder-Details
    Mar 2012
    MN
    Honestly I am looking for a tire more for comfort since I ride a lot. Something that's good in pretty much every condition/ temp except snow. Early spring mornings can be quite chilly, but I've also ridden in huge down pours and 100 degrees. So what I'm looking for is recommendations and sizes.
    Thanks!!!
    Thanks!!!
    For the rear, you might want to consider a 205/60R15 in any good quality & well known brand of 'All Season' car tire that takes your fancy - the often mentioned Vredesteins seem to do very well over your way. The stronger sidewalls & load specs of most car tires will allow (require!??) you to run lower pressure in that tire (16-18 psi, maybe 20 psi if you're reeeeally heavy/heavily loaded/towing! ) than you'd need/is specified for the lightweight Kendas &/or any of their clones in order to maximise traction & wet weather grip, and by running those sorts of pressures you will also improve ride comfort, tire life/even tread wear, and resistance to punctures from road hazards/debris.
    You might need to run a pressure at the lower end of the scale on wet roads to maximise traction & hydro-plane resistance; and at the higher end of the scale in hot weather/on hot roads to avoid over-heating the tire; but very few Spyders/Spyder Ryders generally need anything much more than 16-18 psi in car tires with their higher strength & load specs in order to optimise all those things mentioned and get better performance, ride, handling, and tire life than you generally can from a Kenda/Kenda clone; with the smaller/narrower front tires up front swapped for car tires in the 165/50R15 to 175/60R15 range generally only needing about 18 psi to achieve the same ends.
    I'm currently running a 205/60R15 Michelin All Season Tire very successfully on the rear of my Spyder in much the same range of conditions you mentioned above; paying attention to the pressure variations for conditions that I mentioned of course! But it is very hard to get Vredesteins here in Oz, and almost as hard to get any of the 'other' performance tires some prefer over your way once I leave the 'settled areas' - which is fairly often! . I've done well over 30,000 km on that Michelin, & it still looks so good I am beginning to think that I might hafta eventually retire it due to excessive age before I'll ever wear it out!
    Over to you!
    Thanks!!!
    Since you specifically mentioned " quite chilly " .... the new Vredestein was MADE for you - period ..... Peter always says it Best, I say the same things only use a lot fewer words .... because I'm a lousy typist ..... back over to you Peter ..... Mike
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Amazon has the General Altimax RT43 215/60/15
    INDIANA, USA
    Default Rear tire
    Quote Originally Posted by RudyB View Post
    ...For the money the 'Altima' will be a great tire for your Spyder.
    Good Luck on Your Mission. .......
    Aug 2020
    Georgia
    If you go with a car tire and you want the same size as OEM, this Kumho might fit the bill:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Sold: 2020RT base with numerous improvements and farkles
    Previous 2 wheels: 3 BMWs, 1 Honda, 1 Yamaha and 1 Husqvarna
    Jun 2019
    South Bend, IN
    If I wanted to replace my OEM tire on my 2019 FS-3 the Vredestein Quatrac 205/60/R15 is the correct size to order?
    Quote Originally Posted by JABPA View Post
    Yes - Or the 205/65-15 fits equally ..... if you can't get the " 60 " series tire ..... Mike
    Jun 2019
    South Bend, IN
    Thanks Mike, ordered the Quatrac 205/60/R15.
Tags for this Thread
