Want ideas to get my Spyder on a flatbed pickup for hauling?
I want to haul my F3 limited on a flat bed pickup and haul a camper behind the truck. Any ideas on how to get the spyder on the flatbed. Best ramps to use ect. Any pics or videos would be great.
How did you secure the ramps to the truck bed?
Did you load in reverse?
Was it close to high centering as you transitioned from the ramp?
https://www.discountramps.com/rampag...Trike-Adapter/
You have to purchase the basic ramp to start with. Then you add the spyder adapter. I would suggest removing the windshield before transporting. 4 screws.
Just ran across this. https://www.discountramps.com/big-bo...amp/p/MF3-AMR/
The ramps were constructed of aluminum 1/4" thick 2" x2" X 10 ft long pieces of angle .... connected together using 3/4 X 3/4 in angle & covered with 1/2 plywood .. the ends of the angle pieces were left extended 2" ( & bent to fit ), so I could drill 3/8 in. holes and drop 3 in bolts thru into the edge of the trk bed .... you also should look at my pics in my album ..... Mike
