Page 1 of 2 12 LastLast
Results 1 to 25 of 34
    Jun 2021
    arkansas
    Default Any way to get around the Start up safety message?
    2014 Rts, any way to get around this in the menu? Royal pain waiting for it to boot up seems like it takes forever lol.
    I know about the safety card I have read it numerous times why do I have to be reminded all the time. Maybe someone has a hack work around? New to spyders just trying to learn.
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    My only Can-Am experience is with the Ryker, so my comments are limited:
    1. It may require modification of the ECU
    2. EFI bikes with ECU (ECM) require a "wake-up" time...similar to starting up a computer. On a bike, it is usually the time required for the gauges to cycle. Can-Am is just a bit more complicated and lengthy. Let it go through the cycle while you put on your gloves.
    23 Moto Guzzi V7-850 SE 23 Yamaha XT250 18 Yamaha Bolt R-Spec 22 Triumph Street Twin 20 CanAM Ryker 900 14 Honda CB1100 18 Yamaha XT250 16 Moto Guzzi V7 II 17 Yamaha TW200 12 Triumph Bonneville 02 Sportster 1200 Sport 03 Sportster 883 76 Honda CB750F 75 Honda CB360 70 Yamaha CT1 72 Yamaha CT2 72 Yamaha AT2/CT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda CB160 62 Honda CA110
    2020 900 , NGK 4218 iridium CR8EIX Matte black
    Active Member LongIsland's Avatar
    Dec 2018
    Long Island
    This was just discussed on one of the FB groups I belong to, and it has been discussed here many times. I don't recall any mention of a work around.
    At any rate, I have a 2014 RTL and my procedure is to turn the key to the on position, do a safety inspection of my bike, by the time I get back to my starting point (actually before that) computer has powered up and I can mount the bike and start it right away. Out on a ride, I turn the key to the on position put on my helmet and gloves mount the bike start her up. Oh, I haven't read the safety card since the summer of 2012 with my first RTL.
    May 2012
    Panama City, FL
    Not positive about the '14 models but on my '16 RTS you can turn on the key, press the mode button and press start and the spyder will start immediately. it will take a couple of seconds for the main screen to come up. Dale
    Active Member Stache's Avatar
    Apr 2020
    Flatrock, NL, CA
    Push the mode button as soon as you turn the key on, then hit start
    MWO (Ret'd) SJ Barnes
    ‘20 RTL Stone Grey
    named Britannia in honour of EE Doc Smith’s
    Grey Lensman’s ship.
    Farkles:
    Bestem Carplay
    canamsypderaccessories hitch and wiring harness,
    showchrome trunk rack,
    12v AND dual USB direct to battery in the frunk,
    dual USB switched in the blank console switch spot (parasites the power off the seat heater switch),
    frunk lid organizer,
    trunk organizer,
    showchrome rider backrest,
    ryder and passenger cup holders,
    ram mount for the iPad mini I use for GPS
    quadlock phone mount
    Nautilus horn
    Data blocker on the glove box USB
    Big Bike Parts highway pegs
    Spyderzone dash pouch
    Convex mirrors
    ‘20 Ryker 900 (my wife’s ryde)
    Farkles
    Slingmods fwd/rev ‘suicide shifter’
    frunk organizer
    dual horn
    Max mount
    Rear seat with tall back rest (not mounted)
    Ryder backrest (not mounted)
    Side bag
    Top bag
    top bag makes a good backrest. Will swap on the rear seat if she ever wants to 2up
    2020 RT Limited , Stone Gray
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by Stache View Post
    Doesn’t work on my ‘14 RTS.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Jun 2021
    arkansas
    Thanks for the help, will try the mode button trick and see if it works
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    Quote Originally Posted by LongIsland View Post
    SAME HERE!
    2014 RTL bought in 3/20 with only 6,000 mi.
    Came with Garmin 660
    Car tires in 5/20; Elka stage 2 front shocks in 10/21
    Jun 2011
    Near Lexington, NC
    Get in habit of turning key on before you get on.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Mar 2015
    forrest above Reno, Nv
    Yes there is---------- Have a stage 1 or stage 2 ECU flash and the Spyder will start right after turning the key on. Of course, you get a very nice horsepower and torque increase included.
    Lew L
    2014 RTS , Circuit Yellow
    Katy, Texas
    Quote Originally Posted by d.o.spyder-rts View Post
    That works on my 2020 RTL, Thanks.
    Sep 2017
    INDIANA, USA
    Default 2016 rtl
    My 2016 Spyder RTL does this quickly maybe 5 seconds.
    NOT sure about the other years. Give yours a try and let us know. .......
    ENJOY YOUR LIFE WITH A SPYDER
    Quote Originally Posted by totalcomfort View Post
    I also have a 14 RT .... my " going for a ride " procedure is this .... turn on Key ..... back-peddle or push out of garage .... hit mode button ..... Sp[yder starts , I put on helmet & gloves ./.... turn on Stereo and go for a ride ..... Everything I do MUST be done anyway .... it's all about the order you do it .... JMHOI ...good luck .... Mike PS the last time I read the WARNING was the first & ONLY time
    Vermont
    That works on my 2014 RTS-SE6.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Northern Kalifornia
    What Lew said. I have stage 2 on my 14 RTS and I just hit the start button as soon as I turned the key on. Then hang on for dear life. Zero wait time to initiate launch.
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    Works on my 2014 RTS. I have to wait for the Can Am logo to appear, but as soon as it does, the mode button and start works every time.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Idaho
    It won't. Change was made in 2016 I think. I've read comments where an ECU reflash by one or two guys who can do it will eliminate it.
    2014 Copper RTS
    Jul 2021
    IL
    Not to steal the thread, but having to hit the mode button to start the bike always struck me as odd. But it does make it less likely that a casual thief could figure how to start and steal the bike. I would hit the mode button anyway, as I always leave it in the Eco mode. I like seeing the indicator telling me when it is fuel optimal to shift up even if I don't always shift at that moment.
    2021 Spyder RT
    2023 Royal Enfield Hunter 350
    Retired U.S. Army
    Life Member, NRA
    2021 RT , Petrol (blue)
    Very Active Member Desert Spyder's Avatar
    Oct 2008
    Barstow, California
    The message is there to tell you the computer aka Nanny is doing its job. Do not disturb The Nanny.
    Happy Spyder Owner
    States visited on the Spyder.
    And if we live life without a passion, then we're not living.
    Feb 2020
    illinois
    Thanks for the tip. I have a 2020 RT Limited and went out and tried turning ignition switch on, hit mode button then start switch and fired up. Didn’t know this little trick. May only reduce start up time a few seconds but we all only have so many seconds in our lives and a few saved here and there, well adds to the total…
    Mar 2021
    Haven, Ks
    I did as baxter posted above until I got the ECU flashed by Monster Fuel and had them eliminate the step that required the mode button to avoid. Now, just turn on, put my foot on the brake and it fires right up. I'll have to admit it's nice to not even have to mess with it and just get on down the road. I have my Spyder detailed at a local detail shop once a year and it took forever to teach the detailer how to start it so he could move it into the bay to wax and shine.
    Bartender
    2022 Spyder Sea to Sky
    Jun 2015
    Hampton Roads, VA
    I believe this was changed in 2014+ models; then put back in sometime later. I can start my 2016 and 2021 immediately.
    Idaho
    I'll have to do some more checking to verify things, but this is what I just experienced. If the bike has been sitting not running for at least 15 minutes it will not start until the safety message comes up. However, if I restart the bike within about 5 minutes of shutting it off, pushing mode immediately after turning on the key lets me start it right away. And for some odd reason my bike once in awhile will start without waiting for the safety message. But normally I have to wait for the safety message before I can start. I usually use that waiting time to put on my jacket, helmet, and gloves.
    2014 Copper RTS
    Jan 2021
    northeast pa.
    heres a good laugh, when mine got delivered, guy went over everything with me, so he left, well i turned the key on, hit start button and nothing, could not get it to start, there i sat thinking WTF.. so i went to utube, yep there it was, i had to hit the mode button, so i got it started,,whoohoo... then i had to back it out of the garage, i pushed reverse button, no reverse,, back to utube, there it was, have to hold reverse button while hitting paddle shifter back also.. lol... so i backed it out of garage , and ive had a smile on my face since day one, love this thing, dont miss my 1500 vulcan... cant wait for spring so i can ride again, it really puts a smile on my face, the 2 wheeler did not do that anymore.........
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
    Jul 2014
    Mint Hill, NC
    My experience since day 1 has been the same as IMS.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
