Results 1 to 10 of 10
    Nov 2017
    Florida
    Default Passenger rubber hand bars - any way to repair?
    Hi, the rubber hand grips (bars, handles) on my 2014 RT-S have gashes after I hooked bungee cords to them to carry camping equipment. Is there any way to repair, maybe glue and fill or cover up the rips? Are there any types of leather or vinyl wraps (like car steering wheel) that are attractive that I can wrap or adhere to cover up the damage? I really don’t want to spend the money buying new bars and then pay PowerSports to switch them out.
    Last edited by Peter Aawen; 11-19-2021 at 05:01 PM. Reason: Prefix - not engine/size related; & title clarification ;-)
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    I don't know of any repair products, but check into grip tape for either tennis rackets or golf clubs....
    2020 RT Limited Deep Marsala Chrome
    2020 RT Limited , Marsala Red
    Grip tape for tennis rackets etc. sounds like a good one.
    If you want leather...get some 1/2 wide Saddle Strings from a leather supplier like Tandy or Leather Factory. They are about 40 inches long. They used to come in brown and yellow. Dont know about black...but they could be dyed if you want to match them up with the bike.
    Bossier LoUiSiAna
    Depending on what look you would like to accomplish , could try just about anything Like tacti”cool” -550 paracord does take some skill for tight wrapping & knots
    (just a redneck thought) Also the new Flex tape. Lil pricy but possibly hold up to weather better
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Aug 2021
    CO
    Repair the grips and use Roc straps the next time you want to strap down camping gear. I have been using them for years and you will never use a bungee again.
    Idaho
    Go to a hardware store, or Lowes or HD, and get a small bottle of liquid electrical tape, https://www.homedepot.com/p/Gardner-...E&gclsrc=aw.ds. Fill the holes and gaps with it, clean off the excess, and wrap tightly around the repair area with regular electrical tape. In several days, or a week or two, after the liquid tape has a chance to cure remove the electrical tape. The tears should be filled in and closed up and be hardly noticeable.
    2014 Copper RTS
    Mar 2008
    Hesston, PA
    I had a similar thing happen to my 2014 RTS when I used a lifting strap around both handles to lift the rear section off to replace the air compressor...I used large loom black wire wrap for a temporary fix...I ended up purchasing two new handle assemblies $$$...Stupid move...A live and learn experience for me...(one of many(: larryd
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    I fixed a similar problem with the tape used to wrap handlebars on road-bicycles.
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    Nov 2017
    Florida
    I have looked on line at those handlebar tapes. That would be the easiest and most affordable solution. Can you share a photo so I can see how it looks on your Spyder? R
    Mar 2008
    Hesston, PA
    Quote Originally Posted by Snoozer View Post
    Thanks Snoozer for the info on the "Rok" straps...I order several sets for the Spyder and the ATV larryd
