Results 1 to 9 of 9
    Member pontbrba's Avatar
    Oct 2021
    AL Gulf Coast
    Default Belt vibration at 75 mph - do I need an Idler Pulley/Belt Tensioner?
    Hi all, I知 hoping to get some constructive feedback regarding belt vibration.
    I have a 2020 F3 Limited that I bought new last month. Currently have about 1700 miles.
    When my wife and I were coming home from Pensacola on I-10, I started to feel vibration on my floorboards at around 75mph. When I slowed to 72mph, it went away. I thought it might be ruts in the road from blown out tractor trailer tires and the marks the rims leave, but from what I could see the hwy was smooth. Then at times I could d 75mph with no vibration feeling. After about 10 miles I started to notice that while going up an incline and hitting 75mph the vibration reappeared.
    The next time this happened at 75mph, I continued to throttle and @ 77mph, the vibration went away.
    So with little knowledge I知 surmising that this occurred due to the following reasons.
    1) I was riding 2up
    2) I was going up an incline
    3) the load felt like it was increased due to strong headwinds(it was pretty windy down here in the gulf Coast)
    So when we got home, I知 thinking I need a BRP Idler Pulley(belt tensioner).
    After researching the forums, I知 getting conflicting reviews on installing one.
    My main question is this; does and will the vibration cause any harm/damage to the drive pulley system? Or is it as some have said just an annoyance?
    Or should others have suggested, just adjust the tension on the belt to 160lbs?
    I love riding my Spyder and my wife loves riding with me. I don稚 plan on spending a lot of time on the hwys, but when I do, I want my wife and I to feel and be safe. I知 concerned that the idler pulley is just a item to make me feel happy that the vibration is gone. If the vibration causes my spyders drive system no harm, I知 ok with that. I am concerned that adding a wear item can be more problematic than it痴 worth.
    Thanks,
    Barry
    Pontbrba
    2020 F3 Limited
    Active Member fjray's Avatar
    Aug 2015
    central oregon
    Look around the forum and you will find enough threads about belts and Belt tension to make your eyes bleed from reading them all. Mine vibrated from day one and I could move it around in the speed range but never totally remove it. One of the reasons it lives at a neighbor's house now.
    Feb 2019
    Portland, Oregon
    Here's what I did..........
    The factory/shop setting is too tight.
    I lifted the rear wheel off the floor, loosened the axle just enough so the adjusters can move it. Using a Krikit II on the midpoint of the belt, I get a reading of 140. Rear wheel back on the floor, the reading should be 150 - 160.
    That got rid of 98% of the vibrations. What little come in at 72mph, I can ride around.
    Others here have different methods and readings that work for them. There are YouTube videos also. Check them out.
    YMMV.
    Last edited by Peter Aawen; 10-30-2021 at 10:40 PM. Reason: fl6060oor = floor ?? ;-)
    YMMV.
    .... I did the same to my 14 RT after I brought it home to Vermont, and if there is still some vibes I can't feel them ..... Mike
    Durham,Maine
    X3
    2012 RTL , Pearl
    Sep 2020
    Middletown, NJ
    I had the 75 mph vibes until I added the tensioner to my 20 RT. No more vibes!
    2020 RT base , Chalk White
    Durham,Maine
    Quote Originally Posted by RayBJ View Post
    Keep a eye on the bearings in the wheel!!
    2012 RTL , Pearl
    Jan 2021
    northeast pa.
    same vibration at 70/75 mph, 2020 F3L......... added belt tensioner, no more vibes... i purchased the lamonster one..
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
    Sep 2020
    Middletown, NJ
    I have ~11k mi on the Lamonster rig and have a replacement wheel on the shelf. No sign of wear on the belt or bearings yet.
