Results 1 to 17 of 17
    Aug 2020
    Vermont
    Default Passenger Grab handles (& floorboards) rubber base different rubber? Fading badly!
    It seems as though the base rubber on my passenger grab bars is different rubber or at least a different color compared to the actual handle? I have tried cleaning it with a couple of different soaps and such but it still looks more brown than black. Almost seems like it has something on it as I can rub really hard and some stuff does slightly come off, but not enough to make it black again.
    Mar 2015
    forrest above Reno, Nv
    Have you tried McGuire's " Back to Black" ???
    2014 RTS , Circuit Yellow
    Apr 2021
    Bartlett, TN
    I have the same thing happening on my 2021 RTL and I'm a little anal about keeping my Spyder clean. After every ride I put 303 protectant on the seat and other plastic parts, including those grab bar end covers, and though mine are not as bad as yours, they are definitely starting to change color. This seems to be a common issue with the 2020+ RTs
    2021 Spyder RT-L Deep Marsalsa Metalic
    Aug 2020
    Vermont
    Thanks. They just stick out like a sore thumb with that color. Testing some products now, cleaned with BleachWhite that I use on the white letter of truck tires. That cleaned up (one side only) very well. I'll let it sit for a couple of days with rides in between and let the sun get on it also. I also used some ceramic liquid wax to clean up the plastic and that came up looking good. So I'll wax it in a few days.
    thanks to everyone. Just never saw this before and it happened almost like over night.. Or maybe it was once it was out the dealers showroom floor....LOL
    Active Member sgerksinwi's Avatar
    Jun 2019
    Wisconsin
    Same Issue 21 RT.
    Dealership took pictures to send to Can Am.
    Not holding my breath.
    Dec 2015
    Louisville Kentucky
    Default 2020 RT black rubber caps floorboards
    I’m sorry if this has been addressed, but are the passenger grip black rubber caps and floor board rubber recalled? Ours looks terrible. Thanks
    Oct 2021
    Wichita, KS
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Use Meguiar ultimate black works good like new
    Dec 2015
    Louisville Kentucky
    Works for a day or two, tried it.
    Feb 2012
    Spring City,Utah
    Nothing's going to work for long ,these parts oxidize real fast. I use Back to Black and usually get about month out of it.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Mar 2013
    Maumelle, AR
    I would contact your dealer and open a case for a warranty claim (defective part). I would think this issue is covered under warranty. If your dealer isn't willing to open a case, contact BRP directly and they'll open one. You're not the first person who's had this problem.
    2020 RT Limited , Chalk
    Feb 2016
    My 2020 RTL has the same discoloring of the grab rails too, a dirty brown.
    INDIANA, USA
    Default Fading Handle Base
    Quote Originally Posted by Nuttymopar View Post
    Did Anyone with this issue get it FIXED?
    ENJOY YOUR LIFE WITH A SPYDER
    May 2021
    GA
    BTW, I also posted (a pic) to BRP with a "warranty" question. Also not holding my breath. It does feel better knowing I am not the only one with this. I was sure I had done nothing wrong!
    Aug 2012
    Central Coast, CA
    As far as I know, BRP was also supposed to be investigating these parts for poor fitment and nothing ever came of that either.
    2020 RTL SE6
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    I saw a video of Pierre from canamspyderaccessories use a product called Wipe New.
    2021 RT Base - Petrol Blue
