Results 1 to 17 of 17
    Nov 2019
    Kansas
    Default Would this jack be ok for an 18 F3-L?
    https://www.harborfreight.com/1500-l...ift-63397.html
    Not really sure it would be stable enough? The rest at Harbor freight didn't seem to have the best reviews.
    Mar 2013
    I have the steel one from HF and it works well. The one you are looking at should as well, but don't put the extensions on as it will not fit under your Spyder.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Nov 2019
    Kansas
    Quote Originally Posted by PW2013STL View Post
    Would you mind linking me to the one you have?
    Active Member nslowmotion's Avatar
    May 2015
    https://t.me/pump_upp
    Mar 2013
    Quote Originally Posted by nslowmotion View Post
    That's the one.
    Aug 2020
    Il
    Other than price, any other reason to go with the steel one vs the aluminum one which seems to have better reviews?
    May 2015
    Quote Originally Posted by Pirate View Post
    Dont know about reviews, I have not read any. But, I do know that this has been a very good jack for my spyders. Have not had any problems.
    Jul 2010
    Las Vegas, NV
    I have the craftsman aluminum one. The HF is a direct copy. It’s lighter. I use mine a couple of times a week on jobs. Lighter is better. Moving it, using it, putting it away. I have steel ones, and even a big blue (for sale!), but my go to is the aluminum.
    Joe Meyer
    Jun 2015
    Ritzville, Wa
    Do you know where I can find pics/video that show the lift points for this model?
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Active Member Wheelman's Avatar
    May 2021
    Lakewood, CA
    I have the aluminum one for my F3T and it works great. I would not be doing any heavy wrenching unless you strap it down or put it on stands. I emptied my bags for balance and positioned the jack under the engine, which seems to be the balance point. The picture shows the trike high enough to replace the anti-sway bar.
    Life is not good or bad, it's just Life. Deal with it!
    2018 F-3T, 2016 2500 Ram 4x4, 2020 VW Cross Sport, 2012 Travel trailer
    Northern Kalifornia
    https://www.harborfreight.com/1500-l...ift-60536.html
    That's the one I have. But I would go with what "captjam" said, aluminum if I did it again; and what "Wheelman" said, secure your spider with jack stands after it's up.
    Jun 2015
    Ritzville, Wa
    Quote Originally Posted by Wheelman View Post
    Thanks for the pic.....
    Greg Kamer
    Member pontbrba's Avatar
    Oct 2021
    AL Gulf Coast
    I was on the understanding that the Spyder had to be raised 24” and HF states the lift raises 17”. I’d like to replace my anti sway bar with the Baja Ron sway bar and was considering this lift.
    Pontbrba
    2020 F3 Limited
    Aug 2020
    Il
    Quote Originally Posted by pontbrba View Post
    I was on the understanding that the Spyder had to be raised 17” and HF states the lift raises 17”. I’d like to replace my anti sway bar with the Baja Ron sway bar and was considering this lift.
    I'd be curious about this as well. The swaybar is approx 24" long and the directions mention 20-22" to get the bike raised.
    Mar 2020
    Western New Mexico (Thoreau)
    The aluminum jack looks to have a wider stance. Cost a bit more, but weight and stance would work better, my opinion.
    Oct 2021
    AL Gulf Coast
    Sorry I missed typed raised 17”. I meant to say the spyder had to be raised 24”
    Pontbrba
    2020 F3 Limited
    May 2021
    Lakewood, CA
    I used the aluminum jack to install the new sway bar and it worked great. The jack comes with two extensions that get the trike high enough for the swap. When I lowered the jack, the trike was just barely sitting on the jack. Still able to get the jack out without a problem.
