Page 4 of 4 FirstFirst 1234
Results 76 to 92 of 92
  1. #76
    We do hope that Joel will come back and fill us in with the details.
    I am speculating that the trip is to test out the repair(s) that were made. If the repaired engine does not make the trip, we should be able to hear Joel from wherever he is.
    SoFlo
    Joel, hopefully no more issues with your S2S. Seems this Spyder versus your previous Spyder has tested your patience between the electrical issue and this engine issue. Seems time to enjoy it fully, if your confidence has been restored.
  3. #78
    SoFlo
    By Joels words, another tech apparently mentioned the stuck or carboned valves on another Spyder, plus a computer mapping change, so very likely this has possibly made it to service bulletin status, alerting dealer techs of the issue.
    Hopefully the issue is few and far between, not leaving owners stranded, similar to the older DESS issues.
  4. #79
    Nov 2016
    Upstate NY
    250 miles on the S2S today and a trip to Mount Equinox in Vermont. It ran excellent!! I would almost say the best it ever has. I did change the oil at 6am this morning before the trip. Hopefully all issues with this expensive toy have been resolved. I dont need anymore stress.
    2021 Sea to Sky RT , Highland green
  5. #80
    Dec 2015
    Oakley Utah
    Joel, would you mind telling us what the techs found wrong and fixed? Thank you.
    2014 RTL Platinum
  6. #81
    Nov 2016
    Upstate NY
    They found carbon on the valves causing no compression. 2 cylingers had zero compression and one had 30 lbs. They cleaned the carbon and now all three are nearly 200 lbs.
  7. #82
    Dec 2015
    Oakley Utah
    Thanks. Did they have to remove the heads for that?
    Did they say what caused the carbon buildup and how to prevent it happening again?
    Incidentally, I once owned a 1985 BMW 318i on which they had a recall to clean the valve ports by blasting the head with walnut shells. Interesting.
    2014 RTL Platinum
  8. #83
    Nov 2016
    Upstate NY
    No engine disassembly like I said previously. I was extremely happy about that. The fix was simple. I will let you all theorize about the cause. I have my theory. LOL. And I have heard the mechanics theory. And I have heard from a previous tech and his theory. LOL If it acts up again, then my theory is wrong. I accidently stumbled on my theory after talking to a coworker. Needless to say, I have more questions for him. I am just glad my S2S is fixed without major surgery. That will help me to trust the machine again. I want a spyder I can ride for the next 10 years. My 2014 was extremely dependable and that is what I expect from the S2S. Im signing out on this thread! Thanks to those who provided positive ideas and encouragement. Very much appreciated!!!
  9. #84
    Default spyder fix
    They said they cleaned the carbon. How? Removed the head? I want more answers. Mike, how is it an easy fix? The bike would not start, so you cant seafoam it. I dont believe in seafoam anyway. No fuel additive is going to instantly clean valves. Carbon build up in less than 7000 miles? No way. This spyder will be sold. I am not going to be left stranded somewhere.
    Thanks for answering Your Question ..... ie. the fix was " simple " no engine dis-assembly ie. head re-moval ....Happy you got it fixed ..... Mike
  10. #85
    Mar 2021
    BC
    Man i hope it work out for you. With my air bag issue and other stuff i have read about the s2s getting a little nervous about my investment. Fingers crossed it is fixed. If your theory proves out right and it doesnt come back can you let us know please. I wanna make sure it doenst happen to me.
  11. #86
    Sep 2017
    Durham,Maine
    Thanks for the grand finally and the little secret at the end!!! We love the suspense!! Good Luck!!!
    2012 RTL , Pearl
  12. #87
    Very Active Member taxmyzer's Avatar
    Jul 2013
    Bellmore,NY
    Joel, glad to hear you're back on the road with s2s. Hope there are no more issues for you.
    Ride safe!
    2022 Sea-T0-Sky
  13. #88
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    I guess I missed the FIX. Please educate me. Thanks.
  14. #89
    Bossier LoUiSiAna
    Quote Originally Posted by Bangorbob View Post
    For sure but somehow removed carbon from valves without major disassembly as I understand it. Winner is it is FIXED & not 4sale
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
  15. #90
    Dec 2015
    Oakley Utah
    "carbon build-up " ....if that's true ( NOT ) then it's an easy fix and you have the bike next week .... good luck .... Mike
    I think you probably nailed it Mike.
    2014 RTL Platinum
  16. #91
    SoFlo
    By now, the title of the topic is very misleading and demeaning to other owners.
    It is apparent the engine did not blow up. Merely seems to have suffered from old school 1950s era carbon buildup that rendered two cylinders with no compression and the other at 30 psi. Odd though, to accomplish a compression check, they must have at least gained enough access to remove all the spark plugs. Probably a shot of WD fixed her right up...
  17. #92
    Time to close it down. Gone South to far.
