Page 1 of 4 1234 LastLast
Results 1 to 25 of 92
    Nov 2016
    Upstate NY
    Default 2021 S2S motor dead
    I tried to start my 2021 S2S tonight. Hit the start button. It fired for about a second, then stalled. Tried turning it over and it has no compression and wont start. I might have one of the first 1330s to implode. I have no idea what gave up. I am almost thinking the starter didnt engage long enough, and the engine fired backwards and wiped out the valves, if that is possible. I gave up and went to work. Will look at it again friday.
    2021 Sea to Sky RT , Highland green
    Dec 2013
    Bleedin' eck Joel!! That's not good news!
    Not that it's great whatever way you look at it, but I wonder if it's something not massively drastic like a camshaft not turning for whatever reason?? Are the 1330's a non-interference engine??
    Here's hoping it's a relatively painless fix?!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Dec 2015
    Oakley Utah
    How do you know it has no compression?
    2014 RTL Platinum
    Nov 2016
    Upstate NY
    It turns over very freely and can hear thump in exhaust. It could be camshaft related I guess, but it is terminal, whatever it is. Time to get a new motor under warranty.
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    OMG, Keep us posted, what the issue is please.... Hope you get-r-done before end of ryding-season
    the funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it........
    Spyder F3s 2019 All Black ( Named it: Brutus)
    Carbon Items added, just for looks
    Upgraded Shocks Trac-Tive, Rear hi/lo and rebound adjustable, with Hydraulic Pre-Load adjuster
    fronts hi/lo and rebound adjustable, custom made by the Trac-Tive Guru's
    Swaybar (Ron's)
    Tyres Front Michelin Cross Climate+ 175/60-15
    Rear, for 2022 still a Kenda, next Yokohama Advan Fleva 205/55R15
    Exhaust Bone stock, with a RLS Cat- Delete
    Custom ECU-Mapping, rewritten/adapted to my Ridingstyle
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Bossier LoUiSiAna
    New stereo overpowered the system?! Sorry to hear, glad was not too far out on a trip or something. Know still sucks all the same, excuse the picking; trying add (home improvement)“grunt” MORE POWER crack a smile fun
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Sep 2017
    INDIANA, USA
    Default S2S Engine
    Hopefully you can get it replaced with a new engine.
    What a bummer.
    This is a first.
    ENJOY YOUR LIFE WITH A SPYDER
    SoFlo
    While it certainly could be mechanical, and you being witness would know best. By chance did you pull codes and see if the cam sensor failed? Also, and I suspect you listened, can you hear the fuel pump operating.
    Sorry to hear. Please keep us posted as you get more information.
    Dec 2020
    Down South
    Wow. Sorry.
    Sorry for your loss ..... I hope everything woks out ..... Mike
    Registered Users Motogordo's Avatar
    Jun 2011
    Delanco, New Jersey
    Hey Joel. This is not good news. You helped me a lot with info on my stereo problem. Never heard of a 1330 breaking down. I know you are not happy about that. I hope everything gets fixed quickly. I don't think the word QUICKLY is in BRP's vocabulary.
    best of luck
    Motogordo Spyderman
    Nov 2016
    Upstate NY
    I took it to the dealer today. The mechanic said it was a first. When I say there is no compression, I mean the starter turns almost as if not connected, but you can feel some air from the exhaust. Best guess is, the camshaft chain tensioner failed and the timing chain came off. Another guess is, the crankshaft had a defect and broke and only one cylinder is going up and down and its on the opposite side of the timing chain, which is not turning. It turns over more freely than if you removed the spark plugs and hit the starter. Extremely free. The mechanic is going to check it next week and give an update. I wonder if there is a chance the starter shaft broke, and friction at the break is moving the crank just enough to feel it in the exhaust, but not actually turning over the motor. This would be best case scenario, but the mechanic says the engine would still need to come out to make the repair. The sprag clutch bearing(oneway bearing) may have failed.
    Oct 2020
    Vinton, IA
    Wow, that stinks! My service manual shows an intermediate timing gear that appears to be driven directly off the crank and has (what I refer to as) a step gear that the timing chain mounts to, then travels up to the camshafts. If the gear on the crank (that turns the intermediate gear) is keyed, that key may have sheared; the engine would spin freely and pump air out the open valves.
    If something broke in that geartrain, it's not likely to be an easy fix.
    I sincerely hope they put a new motor in it. It they opt to repair it, be sure to get compression readings off each cylinder, post repairs. The 1330's have 12:1 compression and DOHCs; if the crank is out of sync with those camshafts, it's real easy to bend valves. That might even be something to bring up as reason for a total replacement.
    Best of luck.
    Apr 2019
    Clinton, MS
    Seems like BRP would want to replace the motor just to get a good look at the old one.
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    I'm afraid this may end up with a long, drawn-out dealing between BRP and Rotax.
    "Love 'em all.... Let GOD sort 'em out!"
    2021 RTL Dark Chalk Metallic with comfort seat
    1978 GL1000 w/'75 engine show bike
    1976 RD400c
    Let's hope that if there is interaction between BRP and Rotax, that it will take place behind the scenes. No fighting over which if either is to blame. Get the motor replaced for the customer, it is under warranty. The big boys can duke it out amongst themselves.
    Nov 2016
    Upstate NY
    I decided to pick my spyder up from the dealer today and do the repairs myself. After studying schematics, I have determined that either a starter gear or the sprag clutch has failed. I can do the repair myself in 2 hours or so. No need for engine removal. The mechanic wants to remove the engine. Service manual says that is not necessary. Repair appears easy and straight forward. Cost for parts is $160 depending what is wrong. Small price to pay for peace of mind that it is done correctly. I am extremely picky about who works on my stuff and the quality of the work. This also explains the burning odor I reported a few months ago. The sprag gear was probably hanging up, spinning the starter most of the time while riding. Not good.
    SoFlo
    Quick look at the illustrated parts catalog. Agree with you, the sprag would be a viable cause. Appears the sprag and housing is fastened to the crank trigger wheel, which indicates the sprags inner race is on the large gear. What you say makes sense, time will tell. Yes, agree you remove the engine side cover to access the items you mentioned. Being an RT, the frame clearance should not be an issue.
    Active Member Pooch's Avatar
    Feb 2018
    Texas Hill Country
    At what mileage did this occur… and …. did you notice the burning smell from the very beginning of purchase or after some miles were racked up?
    Just curious…. so I can stay aware with my 2021 RTL… I now have 3700’sh miles on the odo and did the first maintenance at the 3000 mark…tech said everything appeared fine except the lower tire pressures I was running… he aired them up..I let them back down when I got home from his shop.
    Many thanks…
    2021 RT Ltd, Marsala Red/Black, Dark
    New course heading Mr Sulu: 2nd star to the right and straight on til morning...
    Sep 2017
    Durham,Maine
    Let me see, this is a new bike under full warrantee, and you sucked it back from the dealer and going to fix it yourself? As Peter would say, What the bloody hell!! Good Luck big guy!!
    2012 RTL , Pearl
    IMHO if you open that engine up and can't fix it or it turns out that's not the issue and a NEW engine is needed ....BRP may VOID your warranty. ..... just a thought .... good luck .... Mike
    Active Member MrMagicFingers's Avatar
    Apr 2020
    Dartmouth, Nova Scotia, Canada
    EXACTLY what I was thinking. A repair (or potential repair) of this magnitude... These machines cost to much to mess around with. I can see why you want to this yourself with the ridicules times it takes to get work done and the quality of work with a lot of dealers, but that's a roll of the dice to say the least. You may be opening the door to voiding your engine warranty permanently. You got guts!!!
    Tim
    Current - 2010 Spyder RTS
    1) Experience is something you don't get until after you need it.
    2) A closed mouth gathers no foot.
    3) IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU HAVE TIME TO DO IT OVER??
    ___
    Horsepower is an illusory mathematical equation; Torque is REAL, and is the source of all good things in the world.
    The problem is not the problem. The problem is your attitude about the problem. Do you understand?
    Please check out my pics!!
    Some good "counter" advise above. Engine warranty could be voided if things go south on the repair.
    Active Member WisconsinDavid's Avatar
    Sep 2018
    Beaver Dam WI
    I wouldn't settle for a new engine... time to invoke lemon law and require a new spyder to replace. Replaced engines can go okay or be a setup for huge problems down the line. I had a replaced engine by GM due to failed bearings that resulted in a truck fire a few years later when something let go ... not a great experience. Just sayin' from experience. Hope things resolve well for you without a lot of hassle.
