2021 F3 Limited seat removal
i just recently brought home my 2021 F3 Limited. I have a sheepskin cover i want to install on it. does anyone know how to remove the driver seat??
Redneck Diva
Member of the Southern Cruisers Riding Club Chapter #213--Central Georgia
Proud PGR rider
My Manual said to use the key to pop off the passenger seat then use a 10mm socket to remove the two bolts holding the rider seat.
Yep………and when you are using the 10mm socket, I would advise holding a telescopic magnet next to the bolt. It is very easy to accidentally drop the bolt into the “black hole”, never to be seen again, Diva
Pete
Harrington, Australia
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
……..oh….and when putting the rear seat back on, make sure its two front arms are lined up perfectly with the receptacles in the front seat……it can be a real bear.
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
Pete
i wrap tape around the socket and the extension so it cant come off,,, easy/peasy
2020 F3 limited, liquid titanium
grip puppies
Bajaron sway bar
lamonster belt dampener
battery tender
19 in freedom tinted windshield
matte black daytona frunk wrap
Quadtrac 165/60's
We have a 2021 F3L that for some reason came with plastic pushpins where the 10mm bolts should be. I've since corrected that issue. If you find that yours came with the push pins, you'll need to buy two nutplates and bolts. I got them at the local hardware for far less than it would have cost to drive to the dealer to have them put them on.
2020 RT Limited Deep Marsala Chrome
Hmmmmmmm. I imagine it would be a bit testing to get pushpins out in that space, Jetfixer.
Pete
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
I'm guessing the reason was a cost saving measure.
