Results 1 to 20 of 20
Thread: Snow Spyder?
    Jul 2021
    Ohio
    Default Snow Spyder?
    Anybody use their Spyder on snowy roads? If so do you change to more aggressive tires?
    western Colorado
    Yep. Just drive slow.
    Apr 2019
    PA
    Salt........ ROAD ACID (pure brine now days) will eat that spyder alive in one year in Northern Ohio, Pa, NY, VT, NH!
    Active Member MNF3's Avatar
    Jul 2018
    Southern Minnesota
    And Minnesota!
    2016 F3-T , Intense Red Pearl
    Nov 2008
    las vegas, nv
    I think its called ski-doo!
    6 states down 42 states to go
    Active Member ozarkryder's Avatar
    Nov 2018
    Anderson Missouri
    Never took a bike out after it snowed until the snow went away in the spring and it rained a few times to clean off the road when I lived in Minnesota. The chemicals on the road to melt the snow play havoc on the metal bits, and even chrome on plastic.
    BTW - when I read -Snow Spyder- I too thought "I had one of those when I lived up north. Was made by BRP, was yellow and had "Ski-Doo" written on the side.
    2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
    Motorcycle Rights: AMA Charter Life Member, MRF, FORR Life Member Local 11 Southwest Missouri, Mid-South MILE organizing committee member
    2018 RT Limited , Got one, on, then off then on until Gloria decides if she likes it or not. blue
    Quote Originally Posted by Lcfour View Post
    Yes, there have been a few folks the " ones who will try Anything - no matter how silly " and they discovered what 99 % of Spyders owners knew before actually trying it. The front tires start to plow rather than go thru the snow... and the rear, which even has issues on WET roads, isn't going to get you up to speeds that will definately hurt you .... and the Spyder ..... good luck .... Mike
    Sep 2017
    Durham,Maine
    So Mike, what tire would suggest for 8-10 in's of fluffy snow???
    2012 RTL , Pearl
    May 2013
    Apex, N.C.
    I posted a video on facebook a few years ago. I was out playing in my driveway and neighborhood on my F3T. With just the slight incline going up my driveway, it would not get any grip in 6" of snow. I ended up having to shovel it out and parked it back in the garage where it needed to be. I also tried it on my 2014 RT, and it did much better. Probably because there was less snow, and a little more weight on the rear. I would never take it out on the main roads, or any place other than in my subdivision to play. Since I am too old to be pulled in a sled, and don't have a snow machine, this was the next best option for an old man to have fun. Yes, I will do it again. Lol!
    Active Member WisconsinDavid's Avatar
    Sep 2018
    Beaver Dam WI
    Snow, brine, sand, winter is not for Spyders in WI... to say the least for stability on snow ... and unexpected black ice encountered when you don't see or expect it. My Spyder hibernates in the garage on the battery tender when fall is at an end - just like the harleys it has replaced used to.
    Jun 2017
    Rapid City, SD
    I’ve managed to get a monthly ride in every month so far. Usually at least one day a month during the winter where the roads are cleared and dry.
    HE>I
    2017 RT , Asphalt Grey
    Danbury Connecticut
    From many years ago
    But seriously, just slow down more than you would in your car.
    The back end will be more likely to kick out, but the nanny should keep you safe.
    IBA #47122
    2020 RT Limited Asphalt Grey
    I don't think you will go anywhere in 8 - 10 inches of fluffy snow. Your two snowplow tires in front will bog down the drive wheel.
    A few of us have tried the Spyder in snow. It does not work very well. I got stuck in three inches of snow in my driveway and had to push it to get unstuck.
    The front tires act as snow plows and bog the drive wheel down.
    In the event you do get going, stopping is another issue. On black ice covered roads, you are not going to stop. Nanny or not.
    The manual used to say "thou shalt not" when it comes to driving in the snow.
    IMO: Not going to take the chance anymore.
    Dec 2020
    Down South
    Nope, but watched videos on youtube. That's going to be as adventurous as I'd want to be.
    Active Member RideOn's Avatar
    Sep 2018
    Bakersfield, CA
    Same for me. About 4" of wet snow - even though it had 4-wheeler tracks in it - and my Spyder was done. Not enough traction in the rear to overcome the resistance of pushing the fronts through the snow. Fortunately I was able to back out of the snow onto a passable road. Never did make it over that mountain.
    Bob
    “There comes a time in the affairs of men... when we must seize the bull by the tail and face the situation.” - W.C. Fields
    2019 Spyder RT Limited - Asphalt Gray/Chrome
    1991 H-D Sturgis FXDB -- #684 of 1600 Limited Edition
    Gone but not forgotten:
    2014 Spyder ST SE5
    Steel Black Metallic
    2019 RT Limited , Asphalt Gray/Chrome
    Apr 2020
    tucson az
    In Tucson the spyder handles the deepest snow they have ever had in the city. And the winter days are beautiful. Use your favorite snow tire and there will be no problems getting where you want to go.
    2011 rt , pearl white
    Vermont
    Quote Originally Posted by Wmoater View Post
    And Maine.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Vermont
    My spyder hibernates from the Oct. to April.
    As many have already said "The salt, brine, sand, and the spyders don't do well in the winter.
    Also, the insurance companies don't like it.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Feb 2020
    illinois
    had my 2020 rt limited out last winter season after about 4” of sleet. worked well in the neighborhood. later had several inches of snow, now did not have the rear traction and was not moving well.
