2021 RT Trip re set - how can I do this??
How do I reset the trip A & B
Thanks
SCWingman
Push your mode button until trip meter screen shows. Push and hold bottom button to zero. Push side arrow buttons to change from a and b trip meters.
I believe the screen display has a || shown for pressing DOWN on the joystick. That zeros that trip (and it's gas mileage calculation for that trip, too).
"Love 'em all.... Let GOD sort 'em out!"
2021 RTL Dark Chalk Metallic with comfort seat
1978 GL1000 w/'75 engine show bike
1976 RD400c
Originally Posted by bluewoo
Wow, they are actually zeros. I thought they were just two vertical bars. Nice video.
1976 RD400c
August 20, 2021
I have the 2021 Sea to Sky. All I do is push the ECC switch on the left side. Then push down on the joystick until you see Stats. Push stick to the right and A will show up, then push down and it will reset to zero. Push joystick to right again and B will show up. Do the same. If you push joystick to the right again, you will see total odometer miles. Click ECC again and push joystick to House icon and you are done.
If you've been following this thread I'm sure you figured out by now your suggestion doesn't apply to the OP's machine. The dash was completely changed in 2018 and everything about it is different.
2014 Copper RTS
What happens if you accidentally hit the reset on the "Total" page?
Thanks
It won't re-set total odometer reading. At least not on my 22 f3s
Retired U.S. Coast Guard 76-97
Shad bags
Lamonsters 2.0 usb dual power plate
F3 ultimate boards
LED arc lights
Lidlox helmet extender
Lamonsters top cuff with Ram ball and phone holder.
Lamonster billet sway bar end links
BRP driver backrest
LED Volt meter
BIW Cat Delete pipe
Route 129 windscreen
Thanks
What does the owner's manual say, or does it?
2014 Copper RTS
It doesn't say anything.
Hmmm, I understand the written instructions, but strange I get a msg that video is not available.
