Results 1 to 4 of 4
    Oct 2013
    BURLINGTON CT
    Default Steering DPS issues - stiffens up at speed! Help?!
    I am hoping someone can give me some direction on troubleshooting steering issues with my 2010 RT. At idle or slow speeds steering works fine. As soon as you go over 5-10 mph the steering stiffens up so much you have to use all your force to turn it. It is especially difficult in an emergency steering situation where time is of the essence.
    2019 F3 Limited , Black
    Aug 2007
    Greeneville, TN
    DPS stands for Dynamic Power Steering. Meaning that as speed increases, power steering assist decreases. I've been told that at 45 mph, the assist goes to zero. I am wondering if your issue might be computer based. In other words, the input algorithm is somehow being accelerated in your situation. Are you throwing any codes?
    Active Member SpyderJerry's Avatar
    Aug 2017
    Deerfield, Wi
    Also, make sure you check your battery connections. Grab the cables at the battery, if you can move either, clean and retighten the connections. Had the same happen on my 2013 with the same symptoms. Also, helps to put star washers on bolts
    2014 RT SE6
    Quote Originally Posted by SpyderJerry View Post
    .... the DPS has a very large " power draw ", and many here report after checking Battery connections - problem solved. .... but if your Batt. is failing it needs to be re-placed ..... good luck .... Mike
Tags for this Thread
