Results 1 to 20 of 20
    Aug 2016
    Pembroke, Massachusetts
    Default 2021 RT Limited with build date of June 2020. Any problems I should look out for?
    Will be getting 2021 Red/Chrome RT Limited from iMotorsports soon.
    It has a build date of 6/2020 are their any problems I should be looking for?
    Bob
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by RNBOB View Post
    Bob
    I took delivery of my 2020 RT Limited (dark, chalk) in late March, 2020. It had a build date, if I remember right, in February, 2020. I went out and did a quick look and couldn't find a sticker. It did not have any of the issues that the earlier built models had. I would think you should be OK.
    I have 19,975 miles on it and just had my brake light switch and spring replaced under warranty. Other than that, no issues.
    2020 RT Limited , Chalk
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Your bike will not come with a belt tensioner mine was built in November 2020 and did not have one my dealer ordered it for instal. later built will have it installed.
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    If your mirrors are a little blurry when riding, you will need to get the mirror fix from Lamonster Garage. Not all Spyders need this fix. My 2021 RTL built in Nov. 2020 did. Fix works perfect and is an easy job to do. & Welcome to the Forum.
    GLIDE-ON>>>>>>>>>>>>>>
    2021 RTL Chrome , Petrol Blue
    Active Member Schreckftw's Avatar
    Oct 2020
    OH
    I don't think the 21s built pre Sept 2020 have the day night mode on the display.
    2021 RT Limited , Deep Marsala Red Metallic (Dark)
    Mar 2016
    north dakota
    I have a 2021 RT Limited Petrol Blue Chrome bought in January of 2021. It has a build date of June 2020. The mirrors vibrated a little I installed Lamonsters mirror kit and that took care of it. I only have 3000 miles on and no issues.
    Dec 2020
    Hartwell, Ga
    You need to check the vin for the brake switch recall. Other than that and the vibrating mirrors (which is a warranty fix) there's nothing else. I went with Lamonsters mirror fix as I didn't want to fool with the dealer. Any dealer has to honor the warranty.
    Nov 2020
    NE Florida
    Be sure and check for gap and fit issues around the passenger seat. Some built in early 20 had to have zip ties to hold things together. I'm not sure of the manufacture date of when they were fixed.
    RT-S PE#0027 widowmaker2011's Avatar
    Jan 2010
    Orchard Park NY
    That was only affecting 2020 models . Corrected mid 2020 model year. 2021 model year (regardless of production date) should not be affected.
    Back amongst the living May 2021
    2022 RT Limited Hyper Silver
    Out to Pasture:
    2013 ST Limited , Black Currant
    2022 F3L , Dark Edition
    2021 RTL , Chalk Chrome
    2013 RT Limited , Circuit Yellow Metallic
    2008 GS SM5 , Millenium Yellow
    2020 RT Limited Petrol Dark
    2014 RT Limited Champagne Black
    2012 RT Limited White
    2010 Timeless Black RTS SM5
    2010 Orbital Blue RTS SM5
    2008 GS SM5 PE 1941
    2008 GS SM5 PE2011
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    My 2021 was manufactured before Sept. 2020. Mirrors were mentioned already. I just had my front sprocket replaced with BRP's current one due to the whining noise between 45 and 50 in 5th gear. I also had the dealer install a belt tensioner as it didn't come with one.
    2021 RT Base - Petrol Blue
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    My '21 was built this year. The only issue with prep was the tire pressure in all three tires was 10 psi high. Otherwise, Paul delivered it with a full tank of gas!
    1976 RD400c
    Active Member Drwerner's Avatar
    Apr 2021
    NY
    Welcome! Your GPS/Accessory Power Plug may be wired in reverse - this was an error on many earlier production models - I am not sure when when this was corrected. There are simple adapters to correct the reverse polarity. If you are interested, I have a new BRP factory Belt Tensioner for sale.
    2021 Spyder RT-L in Deep Marsala Red/Black - BRP Comfort Seat, Adj Handlebar Riser, Running Board Lights, Driver Backrest, Passenger Armrests. Fobo TPMS, Grip Covers, UltraGard Full & Half Cover, Passenger & Driver Drink Holders, Wide-Vu Side Mirrors, Show Chrome Luggage Rack, SpyderExtras Aluminum Belt Tensioner, Show Chrome Accessory Fuse Block, SpyderExtras Adj Highway Pegs, Carbon Fibre Grills, Full Repair and Maintenance Manual, Kapplock Garmin Nuvo XT Lock & Ram Mount Lock, LidLox Handlebar Helmet Lock, Hopnel Dashboard Storage Pouch/Trunk Organizer/Side Cases, Garmin Nuvo XT GPS, Signal Dynamics Heads Up Voltage Monitor, M1 Motorsports F/R Dash Cam, inView Helmet-Mounted Brake and Turn Signal Light, Pedal Commander w/ Silicone Cover & RAM mount, Spyder Extras Driving Light Bar, Denali D3 Driving Lights, SpyderExtras Light Bar, TAC Designs Side Mirror Stabilizer Kit, Carbon Fibre Trim, Hi-Gain Short Antenna, Headlight Skins, Mirror Turn Signal Lights.
    2021 RT Limited , Marsala Red/Black
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by widowmaker2011 View Post
    You're right, my bad. I saw the 2020 build date and thought of the 2020 early model brake recall.
    Jul 2021
    St Augustine, Florida
    Bob
    How do you find out what the build date for your Spyder is?
    Aug 2016
    Its on the label with the vin# and Gvwr.
    Mike from I motorsports sales took a picture of it and a separate picture of the trike and sent them to me.image0.jpg
    Jul 2021
    Ok
    Second dumb question, Where is that sticker?
    Aug 2016
    Quote Originally Posted by TomTom View Post
    Ok
    Can't tell from the picture. Look for the vin# its on the same label.
    Dec 2020
    Hartwell, Ga
    Ok
    Look under the drivers seat
    Very Active Member MRH's Avatar
    Apr 2012
    Los Angeles and Santa Ynez, CA
    Time can be a big issue, it tends to disappear when you take these out. There is also a tendency to end up much farther from home than you expected.
    (Do make sure they take care of any bulletins before they deliver it, including the gap between the back seat and plastic around it, but there aren't any major issues I'm aware of. For me, a the Baja Ron (anti-) sway bar was a necessity.)
    2020 RT Limited in the ultra cool Deep Marsala Dark edition.
    Baja Ron Anti-Sway Bar, LED reflectors, Lamonster USB Charger (and phone mount), Can-Am Low Windshield, X-Creen Tour Variable Windscreen Spoiler Blade, Power Commander, Dilithium powered Flux Capacitor (not yet fully functional).
    Maintained by Lou at Pirate Powersports.
    Active Member RideOn's Avatar
    Sep 2018
    Bakersfield, CA
    Ok
    The label with the VIN is on the left side of the rear swing arm. At least it is on 2019 RTs and 2014 STs.
    As I recall there is a label under the seat with the exact date and time of build.
    “There comes a time in the affairs of men... when we must seize the bull by the tail and face the situation.” - W.C. Fields
    2019 Spyder RT Limited - Asphalt Gray/Chrome
    1991 H-D Sturgis FXDB -- #684 of 1600 Limited Edition
    Gone but not forgotten:
    2014 Spyder ST SE5
    Steel Black Metallic
    2019 RT Limited , Asphalt Gray/Chrome
