Results 1 to 3 of 3
    Feb 2018
    Florida
    Default Will I lose saved settings by doing a Battery Change?
    In changing the battery in a 2018 Spyder RT Limited will you lose any settings (radio stations, etc.) when you disconnect the old battery?
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by floridarider View Post
    No. The only thing you lose is the clock.
    2020 RT Limited , Chalk
    Active Member spyderider1's Avatar
    Jan 2018
    Wisconsin
    No, you're good, settings will be saved once you reinstall the battery. But getting the little bugger in and out of there is the challenge. Set the bottom in first and tip the top of the battery in last, reconnect your cables and you're all set.
    LORD GRANT ME THE SENILITY TO FORGET THE PEOPLE I NEVER LIKED,
    THE GOOD FORTUNE TO RUN INTO THE ONES I DO LIKE,
    AND THE EYE SIGHT TO TELL THE DIFFERENCE.
    2016 Spyder RTS
