Results 1 to 15 of 15
    Jun 2021
    New Mexico
    Talking Rear Cargo panniers/saddlebags won't stay locked?? Anyone else? 2020 F3T
    Anyone else having a problem locking the rear cargo? It won’t stay locked! I own a 2020 F3T
    Help please! TIA
    Jun 2015
    Hampton Roads, VA
    Mine takes a couple pushes to lock. I got the service manual, if I find how to adjust I'll post
    Jun 2021
    New Mexico
    Unhappy Rear cargo
    Steven, I tried that! Several times! It just won’t and the light is on telling me it’s open.
    Let me know what you find out please!
    Jul 2021
    Ohio
    Good morning, I'm not sure if you found the fix for your issue, but there is an excellent YouTube video that demonstrates how to fix that. It also deals with the warning light being on, even when the cargo compartment is actually locked. It's called The SmoaksVlog #2053 and #2054. I hope this information helps you. It was sent to me by a member of my Spyder Rider's Group.
    Jul 2021
    Ohio
    Sorry for the omission, it was a YouTube video.
    Jun 2021
    New Mexico
    Default Cargo
    Kfrank
    Thank you so much! Will look it up!
    Jul 2021
    Ohio
    You're welcome.
    Jun 2021
    New Mexico
    Hi again! So watched the video, thanks again by the way, but my problem is the rear cargo saddlebags. I don’t have one of those that the video discusses therefore not the same hardware. Bummer!
    I can’t believe no one else has had this problem! Lucky me…uuugh!
    Thx again!
    Jul 2021
    Ohio
    GoldenGirl, I'm sorry that my response did not help you fix your problem. If I see something else, I will be sure to let you know. Best of luck.
    Active Member Wheelman's Avatar
    May 2021
    Lakewood, CA
    I had a similar problem on my 2018 F3-T. You may have already checked this but I found that the plastic divider that runs the length of saddlebag had slipped out of position. It needs to be in the slots at the front and rear of the bag for the case to close completely. Hope this helps.
    Life is not good or bad, it's just Life. Deal with it!
    2018 F-3T, 2016 2500 Ram 4x4, 2020 VW Cross Sport, 2012 Travel trailer
    Jun 2021
    New Mexico
    Default Cargo
    Thank you! I will check that out.
    Active Member SpyderJerry's Avatar
    Aug 2017
    Deerfield, Wi
    On my rt which uses the same type of latch. I found that the return spring at the latch was on the wrong side of the release lever at the latch. had to remove latch and reinstalled spring on the cable side of latch. It would latch and then open going down the road.
    2014 RT SE6
    Jun 2021
    New Mexico
    I figured it out!!
    I opened the cargo. Turned the key to lock. Pushed in the latch and they both locked (while open). I then closed it and it stayed locked! Yay! What it’s gonna do when I open again I don’t know! For now at least the light is off on dash. Thanks everyone that responded. Appreciate it!
    Jun 2021
    New Mexico
    Well, so much for that! I went over a speed bump, slowly I might add, and it popped open! Uuugh!
    Still have not been able to lock it shut!
    Aug 2015
    iowa
    Since it's a 2020 F3 I would take it back to the dealer and have them fix it. Should be covered under warranty.
