Results 1 to 9 of 9
    Active Member JCWeatherman's Avatar
    Aug 2015
    Lancaster County, Pennsylvania, USA
    Default Pulling a Bushtec Trailer
    Greetings to all,
    I'm looking for advice from anyone who pulls a Bushtec trailer.
    Questions:
    1. Are you able to use Bushtec's pin (instead of a ball) coupler? If so, how does it handle? Did you have to do anything special to mount the pin?
    2. If you already have Can Am trailer wiring, do you need any of the isolation systems and special wiring harnesses that are mentioned in other posts?
    3. Does Bushtec still use tires with inner tubes in their tires? I can't tell from their website, but it looks like they still do.
    Thanks in advance. I'm trying to get this sorted out to avoid future problems.
    All the best,
    John
    All the best,
    John
    2022 RT Limited
    • Garmin XT (I would be lost without it)
      Driving Lights (Very bright to improve my sight)
      Floorboard Lights and Turn Signals (I like to be seen)
      Passenger Armrests (So my wife doesn't fall off)
      Trailer Hitch (So we can bring more stuff with us)
      Chrome Wheels (Because the beautiful stock wheels just weren't good enough)
      Front Fender Sequential Reflector Lights (I was wondering what to do with my paycheck)
    Quote Originally Posted by JCWeatherman View Post
    Greetings to all,
    Questions:
    All the best,
    John
    As far as the " bushtec PIN " I have something similar that I made using an auto " tie-rod " end .... I also made my Tow Bracket from a piece of Alumin. angle with a small hole frilled to accept the bolt end of the tie-rod ..... There is NO slack in this set-up so no clang- clang, .... I seriously doubt those tires are TUBE type ..... Mike
    Mar 2013
    Maumelle, AR
    Greetings to all,
    Questions:
    All the best,
    John
    If you contact Bushtec direct, they'll answer your questions. They're pretty helpful. Also, Bushtec makes a plug n play wiring harness for the Spyder ($165.00) although, they're out of stock right now. Their supplier can not get the parts to make them.
    2020 RT Limited , Chalk
    Apr 2021
    Ky
    I pull a trailer with my HD, I strongly suggest putting a hopkins powered converter on the trailer. Some models are waterproof. From the constant 12volt supply, you can add a charging outlet on the trailer, hot when the bike is on, hot always or one of each.
    Aug 2015
    Default Plug n Play wiring harness
    Quote Originally Posted by Copperman View Post
    Is that the same wiring harness that Show Chrome sells for about $65? If not, would it do the same thing?
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    All the best,
    John
    2022 RT Limited
    Aug 2015
    Quote Originally Posted by Hoginedgewood View Post
    I searched for "Hopkins Power Converter," and it looks like a great product, but not what I need. It converts to 4 pin trailer; I need 5 pin trailer. Thanks!
    All the best,
    John
    2022 RT Limited
    Mar 2013
    Maumelle, AR
    I do not know that.
    Active Member Supercrawler's Avatar
    Nov 2020
    California
    Bushteh has very unique balllock when my 2021 Rtl bottom out it will hit the License plate.
    It need to be modified.
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    Amazon shows a Hopkins 4 to 5 converter. 4 wire vehicle to 5 wire trailer. For $9.75
    1976 RD400c
