Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 55
  1. #26
    Quote Originally Posted by spyder01 View Post
    Couple points here,first this is the 1300 motor so I dont think vac hoses or canisterectomy even apply.Second crank sensors are notorious for being sensitive to heat,they tend to fail when they get hot so its common to start and then fail after engine warm up.They usually will set a code but sometimes they dont.The ohms testing procedure one guy noted will only test to see if the wires from the ECM down to the sensor are ok,it wont test the sensor.IMHO there is no reliable way to test the sensor,yours is probably bad and just replace it.One other thing is when I see oil coming out of a sensor it means that the sensor has micro cracks that allowed oil to enter and that can cause failure.My opinions are based on 25 years of owning a shop that did a lot of computer related type work on cars and trucks which use the same systems as your Spyder.Funny thing was when I replaced the cam sensor on my 17rt I noticed it looked like the same sensor that I had installed so many of in many cars which shall remain nameless.
    The OP has an STS which never had the 1330 engine and the V-twin were notorious for vacuum hose failure ..... Mike
  2. #27
    Active Member ARNIE R's Avatar
    Mar 2017
    Leesburg, VA
    Ordered a new CPS unit - still about 15 days until its available.
    Silicone vacuum hoses - are these things as rare as hen's teeth? Called 4 NAPA stores today and no 1/8 inch anywhere. Also called about 5 other auto parts stores without success. One place referred me to a nearby company that deals with all sorts of tubes, hoses, lines, etc. Poor guy on the phone found 1/8 inch hose but was not sure of its type - close to their quitting time, so he probably didn't want to get too involved in finding out.
    Guess I'll buy something online as I see many sites that sell the stuff.
    Fun times ahead.......
    Thanks for all the comments so far.........
    2014 ST-S Cognac
    2014 ST-S , OEM Yes Cognac
  3. #28
    Oct 2015
    Lynden, WA
    PM me your address. I will send you a foot of the silicon hose I have left over from
    working on my 2013 STS.
    I also did a canisterectomy and was very pleased with the results.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
  4. #29
    Mar 2017
    Leesburg, VA
    Quote Originally Posted by Haze View Post
    Thank you, that is very kind of you.
    PM sent.
    2014 ST-S Cognac
  5. #30
    SoFlo
    Apologies for coming back late and not replying to your question asking about the hose location.
    Seems you have that well in hand and hopefully have gotten your stalling issue resolved.
    You may want to read up on how to correctly clean the throttle bodies. Apparently, dealers are not doing this and merely selling replacements at big bucks. Unless broken, correctly cleaning them resolves many “how it runs issues” also.
  6. #31
    May 2018
    millsboro,delaware
    Guess I missed that it was a 998 motor,but I think he still needs a crank sensor.
    : 2017 RTL ORBITAL BLUE
  7. #32
    Mar 2017
    Leesburg, VA
    I have already ordered one to be on the safe side.
    2014 ST-S Cognac
  8. #33
    Mar 2017
    Leesburg, VA
    Wouldn’t surprise me if they left something loose or inadvertently “screwed” something up when the bike was in their shop for the valve cover gaskets leaking. Had the bike almost a whole month and obviously had to take things apart here and there. I also recall a comment from the service advisor when I picked it up. He made a specific comment regarding the vacuum hoses being a weak spot but did not elaborate any further, Wonder if he already knew something…….
    Anyway, one of kind members here is sending me some silicone hose - much appreciated!
    2014 ST-S Cognac
  9. #34
    Mar 2017
    Leesburg, VA
    Two observations today.
    In anticipation of installing the new vacuum hoses, I pulled off some body panels in advance. Is it factory custom to use black zip ties around the vacuum hose where it attaches to the MAP sensor. There is one zip tie only on the hose that feeds to the rear cylinder, but none anywhere else. Also, out of curiosity, I also rechecked for any codes and had 1175 show up before I even started the engine. I believe this one refers to the rear cylinder running rich? I had no codes showing after my ride the other day after cleaning the CPS. Wonder if that zip tied vacuum hose to the rear cylinder has any connection with that code.
    After running the engine for a few minutes, the code did not appear again.
    2014 ST-S Cognac
  10. #35
    Bossier LoUiSiAna
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
  11. #36
    Mar 2017
    Leesburg, VA
    Wow. Scary reading all that.
    Just left my dealership after conferring with the service manager. As I already knew what he repeated about the original oil leak repairs not being related to the current codes, I did stress that I was concerned if something may have been damaged, installed improperly, etc since all of this started after the oil leak repairs. Being backed up, appointment -wise til the end of August did not sit well with me as it would sit in their lot in the event that a blank time slot just happened to unexpectedly open. He finally agreed to have it looked at this Wednesday, so I will drop it off and see what happens.
    He also stated that these type of events tend to frequently occur in the “older style” Spyders and I should get used to it happening.
    The first four years went well- all of this started after the oil leak job.
    Was planning on going riding tomorrow but I feel very apprehensive about it.
    2014 ST-S Cognac
  12. #37
    May 2020
    Pennsylvania
    Just a thought ----- I have, on several occasions, had the vent on the gas cap get plugged up by the dust we all kick up on our travels and merely cleaning the vent solved the problem. Your issue of the motor running for several minutes without issue and then suddenly, being starved of fuel, stumbling and dying is typical of a clogged gas cap vent. That might not be your problem, but it surely is a simple fix ! Good luck ------ Bob
  13. #38
    Mar 2017
    Leesburg, VA
    Quote Originally Posted by ARNIE R View Post
    Speaking of vacuum hoses - before I went to the dealership today, I noticed that the vacuum hose attached to the rear cylinder had a black zip tie wrapped around it at the MAP fitting. When I asked the service manager if this was a normal factory procedure, he stated that it was something that they did at the service department if they found the "original metal clamps" were no longer tight during a repair, so they zip tie it to make it tight again. I wasn't aware that there were any metal clamps used on the fittings - at least the other 3 connections have none.
    So, after arriving home, I took another good look at the vacuum hoses. I gently tugged at the zip tied fitting and the hose literally slipped off. Removed the zip tie and tried putting the hose back on, but it was entirely too loose. That may be related to the P1175 code I got for the rear cylinder.
    I am not too confident in their service department any longer, and, it turns out the service manager doubles as a Yamaha technician, since they sell Yamaha, Suzuki and Kawasaki products as well. He admitted that he was not all that familiar with the layout of the 998 Spyder engine..........geez.
    2014 ST-S Cognac
  14. #39
    Bossier LoUiSiAna
    Thx more aggravation than scary. Still enjoying the ride just more awareness & attempt to gather info might find the gremlin. As far as “older style” ya anything with age has “STYLE” . Don’t let apprehension spoil a good ryde, join an escort bud &/or good roadside assistance like AMA. They good machines, just need TLC to keep them/You going, & going, & going, refill, repeat fyi@69k+ now
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
  15. #40
    SoFlo
    I am going to ask a harsh question. As a kid, did your mom tell you not to touch the hot pan on the stove? But likely you did anyway. Learned a lesson not soon forgotten.
    In simple terms, realize your dealer may be that hot pan. You got burned once, seems unlikely the pan has cooled yet based on your previous reply. Don’t get burned again. Realize too, putting BS onto burns does not heal them faster. A service writer might tell you whatever they deem needed at that time. Does not always mean it is true.
  16. #41
    Sep 2017
    Durham,Maine
    I think I would run like a deer from that shop, wait till you get that tubing from the member that sent it to you, put it on, and see what happens after that!! I baffles me that you could not get it at any of your Napa stores to start with! Good luck
    2012 RTL , Pearl
  17. #42
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    Once you finish the probable causes if don't find the problen could see for spark plug wires or cable problems on the right handlebar control
    2018 F3 Ltd. , Black/Dark
  18. #43
    Mar 2017
    Leesburg, VA
    I now suspect that dealer applied zip tied vacuum hose is/was a major contributing factor to my initial engine problems.
    As an experiment, I attached a temporary smaller zip tie to the vacuum hose fitting - one that I was actually able to attach tight enough so that I could no longer pull the hose off by hand. The dealership had used a big one that is usually seen on the frame holding wire bundles together.
    Filled the tank with gas and Seafoam.
    Went out for a 225 mile ride thru small towns and interstate highways at various speed ranges.
    Engine ran great - very smooth at all speeds. Actually hit 200 miles on the gas tank where my normal is about 175.
    Keeping my fingers crossed that the new silicone vacuum hoses do the trick, and, that new CPS unit when it arrives.
    2014 ST-S Cognac
  19. #44
    Bossier LoUiSiAna
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
  20. #45
    SoFlo
    Sounds good. Regardless, replace the parts. Not worth getting stranded, especially if the sensor is intermittent, or possiblely you somehow lessened a vacuum leak. The hoses are a known problem.
  21. #46
    Mar 2017
    Leesburg, VA
    Absolutely. As soon as the new parts come I, on they shall go.
    2014 ST-S Cognac
  22. #47
    Very Active Member SNOOPY's Avatar
    Aug 2013
    I have a 2013 STS and wondering if I should have a sensor on hand if this is a common thing? How much do the sensors run and is it easy to access?
    About how many miles do you have on yours?
    Only time in the past I had a stall issue I think it was due to those hoses.
    Thanks
  23. #48
    Mar 2017
    Leesburg, VA
    Quote Originally Posted by SNOOPY View Post
    Thanks
    Part plus tax and shipping was about $107 from Cheap Cycle Parts. Not sure how common it is - it just showed up as a trouble code on the gauge cluster, so I'm replacing it to be safe, and upon the advice of some helpful members' suggestions.
    2014 ST-S Cognac
  24. #49
    Mar 2017
    Leesburg, VA
    The hose section arrived today as I was in the middle of doing an oil change, so while the panels were off, I replaced them. Kinda tight in there, but I got it done. Nice color by the way. Thank you again for your generosity. I'll be doing a ride tomorrow feeling a little better.
    2014 ST-S Cognac
  25. #50
    Mar 2017
    Leesburg, VA
    Got the new CPS unit installed yesterday along with the new silicone vacuum hoses a few days ago. Had a nice long 250 mile ride and everything went well - except for that dang thunderstorm that came the west and chased my butt back home for 60 miles. I did beat it, however......
    Thanks to everyone for your comments and suggestions.
    Guess I will look into the canister thingy next - seems simple enough by the posts I've read.
    2014 ST-S Cognac
