Oil Change F3T
Getting mixed messages regarding oil drain plugs.
What are the tools required to remove trans and engine drain plugs ?
Crankcase plug is T45 Torx, clutch cover, aka transmission, 6mm Allen.
I had to ALL WAYS look at the hole to remember witch was witch! Now I just put a wrench on them, got a set of gold plugs from Lamonster!
Get the Gold pugs as mentioned above, and you will like that a lot better. You use a set of sockets and a ratchet to take them out and it is a lot easier!
Reason: socks = sockets ;-)
Thanks for the info. Oil change coming up, I'll try and get gold plugs for the next one.
