Using Gates Carbon Drive App to Check/Adjust Belt Tension
This YouTube video on belt tension of a 2018 RT Limited
Uses the Gates Carbon Drive phone app
Does anyone have experience using this app to check/adjust belt tension?
https://youtu.be/pWGiCt7aW6s
You just need to hold the mic end of the phone close to the belt when you pluck it. I get around 31 Hz.
1976 RD400c
That would only be 801 Newtons
And 180 ft lbs
Is that the correct range for your belt per your manual?
Tire off the ground and 3 reading average?
FYI
This thread has detailed information on required min-max hz readings for ACE 1330
ACE 1330 Belt Model RT (Newtons)
Min (900n) Spec (1050n) Max (1200n)
(Newtons)
Belt Spec 1050+/- 150n
Frequency range in HZ
Min 32.34hz Spec 34.93hz Max 37.34hz
https://www.spyderlovers.com/forums/...s+Carbon+Drive
Originally Posted by PMK
Unless you run a belt tensioning / damper device, it will vibrate at those specs.
The spec range is 202# to 270# in the air -- I'm at 200# (average, loose/tight) and mild vibration starts at 75mph. It's 235# on the ground. I don't mind the 75mph vibration since I rarely go that fast. The real problem for me is the return of the whine at that tension, when compared to 180#. But, at 180# the vibration was in the 60s.
Even though there is no evidence of a problem, I'll change the front pulley, probably next winter, and hope that eliminates the whine.
I think there is a lot of variability in tension measurements from person-to-person and method-to-method. That and several different belts, models, and tension specifications leads to much confusion. I like staying within the factory spec (almost).
Head in the game, eyes down the road... 2020RT
Spyder Tryke Pylot
Really? So OEM manual specs cause vibration
So what specs do you suggest?
Well this sounds cool.Does it really work?
2021 RT Limited in Marsala Red & chrome (9/20)
2006 Yamaha Royal Star Venture - Black Cherry
2003 Suzuki Volusia - Black w/ Gold
1973 Honda CL350 - Hawaiian Blue
I am going to order this external microphone for my iPhone and clip in location so the average hz reading will come from same distance and better than built in microphone
Professional Grade Lavalier Microphone with Adapter Compatible with iPhone - Lapel Microphone for iPhone 5 6 7 8 X 11 Pro Max - iPhone Compatible External Microphone - iPhone XR, XS, XS Max Microphone https://www.amazon.com/dp/B07Y1XBKC7...4R823M395SPE4K
If you read the link from these forums the app was checked against a professional Gates Belt HZ reader and was reported to be very accurate. At least close enough to confirm it works
Wouldn't work on my cell phone, but no reason why it would not give an indication of the tightness. I have a guitar tuner that works the same way. Clip it to neck, turn it on and pluck / adjust. Gives a perfect tune every time.
My Moto G6 Android cell can't hear below 50Hz, so it's a no go for the Gates app. I actually use a (carefully qualified) guitar tuner to adjust my belt. Works great.
Spyder Tryke Pylot
Think I'll stay old fashion!!!!! Works for me!
What is “old fashion”?
My manual says belt tension is done by Newtons
