Page 1 of 2 12 LastLast
Results 1 to 25 of 28
    May 2019
    Mt. Juliet, TN
    Default What RPM range do you stay in (mostly) 1330 engine?
    Curious what RPM most of you hover around with your Rotax 1330 Spyder? Also, do you have a high end rev where you tend to go before shifting?
    Sep 2020
    Middletown, NJ
    I like 3500-4000 rpm range on my '20 RT. I rarely exceed 6000 unless doing a quick pass or 'spirited' take-offs.
    2020 RT base , Chalk White
    Mar 2015
    forrest above Reno, Nv
    Well kinda depends on the situation. When running with the sport bikes on the loneliest road in the country ( Hwy 50 that is basically unpatrolled), we'll run at 4,500 or so on some long stretches. Shifting --- anywhere between 3500 and 7,000
    2014 RTS , Circuit Yellow
    Another vote for 3500 - 4000. At these rpm's, shifting up is seamless and quiet. A great rpm range to cruise in. We do not use sixth gear unless we are over 60 mph. And of course...running it up for a "spurt" of speed for a pass, etc. also is good.
    I still let the gears shift down on their own about 98% of the time.
    For normal A to B trips I use 6th gear ( SE trans. ) at about 2200 rpm's any higher and it's above the speed limit on 98% of the roads I'm on.... In the " twistie's " it's a whole different thing .... Un-like the V-twins with a different type of clutch which required a minimum of about 3200 rpm's to stay fully engaged, I find the 1330 with SE trans is pretty much fool-proof from the factory ..... You can't LUG the engine even if you tried to ... the trans will downshift at a set level which has been determined by the engineers..... Also the SE won't let you Up-shift until a certain RPM is reached .....Mike
    Feb 2019
    Portland, Oregon
    I don't know about others' bikes, but when the revs on mine drop below 3K RPMs, I hear a deeper note, like it's beginning to lug. So I keep it above 3K revs. I tend to ride aggressively and like the faster throttle response with higher revs. I don't go into 6th gear until she's in the higher 60s, almost or over 70 mph.
    Northern Kalifornia
    3K is my sweet spot mostly in 6th gear. If I'm merging into traffic I'll use the extra HP built into the 1330, but again 60 MPH is my comfortable speed range. When s**t happens it happens real fast, even at 60. Yes, I've driven faster before but I don't like it. I've gotten some unbelievable MPG at lower speeds and RPM's on longer rides while enjoying the scenery too; something you don't get at 75/80 MPH.
    Jul 2014
    Mint Hill, NC
    I agree with Lew, it depends on where and how you are riding, and I find the sweet spot shifting in the 3K - 3,500 range but will run it higher if I'm in tight twisties where I use engine braking to the extent I like.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    Agree with Blueknight, on this subject, for me when cruisin, roundthe 2200/2400 rpm's, when really driving the Spyder (usually one-up), I tend to be round the 3000/3500 rpm, I simply don't see the need for 6000 rpm's, cause that's for flying really low...
    I hit that high rpm's when taking a flying start, but I don't think the bike performs at his best at high rpm's,
    Between the shifting range of 3000/3500 and 4000/ 5000 rpm's the torque is at his best for the 1330.
    But I remapped the ECU, for more torque in the low end of RPM's, cause that just fits me the best.
    the funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it........
    Spyder F3s 2019 All Black ( Named it: Brutus)
    Carbon Items added, just for looks
    Upgraded Shocks Trac-Tive, Rear hi/lo and rebound adjustable, with Hydraulic Pre-Load adjuster
    fronts hi/lo and rebound adjustable, custom made by the Trac-Tive Guru's
    Swaybar (Ron's)
    Tyres Front Michelin Cross Climate+ 175/60-15
    Rear, for 2022 still a Kenda, next Yokohama Advan Fleva 205/55R15
    Exhaust Bone stock, with a RLS Cat- Delete
    Custom ECU-Mapping, rewritten/adapted to my Ridingstyle
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Jan 2021
    northeast pa.
    3000-3500 is the sweet spot on my 2020 f3l..
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
    Sep 2017
    Durham,Maine
    I can't wait to become a big boy and get the 1330!!!
    2012 RTL , Pearl
    Active Member T.P.'s Avatar
    Oct 2016
    APPLE VALLEY, MN
    Just an FYI here, The 1330 has a redline of 8100 rpm So don't think your over doing it.
    with the PV3 you get it increased to 8400 and with the Monster tune you can up that to 9200
    T.P.
    Very Active Member CloverHillCrawler's Avatar
    Mar 2021
    Maryland
    I usually shift between 3200-3500 and I dont go above 4k unless I am out on the highway. One thing I have found out with the twisties on some of these back roads around catoctin mountain is the Spyder is a bit harder to control going downhill on a 10% grade riding the brakes/downshifting. But going uphill you can stay in 4th gear on a 10% grade and have some real fun with the twisties!
    2020 F3 SE6
    Safety and Lighting: LED Headlight upgrade, IPS LED Fog lights, Show Chrome LED Fender Signals, LED Signature Light, Tric LED Afterburnerz, MotoHorn 2.0
    Suspension: Wilbers Front and Rear Shocks, BajaRon Sway Bar, Vredestein Quatrac Front and Rear Tires
    Comfort: Blue Ridge Windshield, Corbin Dual Touring Saddle, Ultimate Floorboards, OEM Passenger Backrest with Rear Shelf, OEM Passenger Floorboards Modified with High Risers from Pierre
    Tackform Center Mount Phone Holder w/ rapid charging USB-C.
    2020 F3 , Black
    Quote Originally Posted by CloverHillCrawler View Post
    Going down mountains, and we have a couple nice ones here, we usually shift it down to second and let the engine do the braking. it works fine in second coming down the stretches that it took first gear to climb up on. Very rarely do we even use the brakes coming down a mountain.
    Active Member BadMonk's Avatar
    Apr 2021
    PA
    A wee bit over 3,000 for cruising.
    5500 is the sweet spot on the 998. Lots of power to get up and go when you wake that 998 up. Higher red-line too. If memory serves, I believe it was 9500.
    Registered Users Motogordo's Avatar
    Jun 2011
    Delanco, New Jersey
    I haven't gone past 3300 RPM's on my Sea to Sky.. Casual shifting is around 2200 rpms
    Very Active Member rjinaz86323's Avatar
    Mar 2021
    Arizona high country
    on my '18 F3L. 3600 rpm is 70 mph. The interstates in AZ are marked 75 and you will get run over if you are not going 80 or better. I don't like to ryde the freeways, but I have little choice if I am going anywhere but day rydes.
    . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2018 F3 Limited - Intense Red Pearl . . . . . . . . . . . . . . . . . . . . . . . . . . .
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by Motogordo View Post
    You are not being kind to your engine, especially during break in. The rings need revs to seat.
    Dec 2020
    Hartwell, Ga
    It's your bike but you really need to at least take it up to 2900 rpm before shifting (that's where the eco mode wants you to shift). I mainly shift between 3400 to 3600 myself.
    I promise you'll have smoother shifts at these rpm's.
    Jun 2021
    wisconsin
    Quote Originally Posted by T.P. View Post
    T.P.
    It's actually rated at 7250. At 5000 torque is already falling and @ 6000 it's falling like a rock if you look at the dyno sheet.
    Jun 2021
    wisconsin
    106hp @ 8500 was the rating.
    Dec 2018
    Elanora, Qld, Australia
    3500 rpm is my usual for 2020 F3L depending upon environmental situations. Engine sounds and acts happy. Not frightened of 5000rpm+ but prefer to not waste too much fuel too often.
    There is usually another way. 2020 F3Ltd.
    2020 F3 Ltd , Brake Pedel lowered. Liquid Titanium
    Sep 2017
    INDIANA, USA
    Default Engine Rpm Sweet Spot
    Seems like most have the Spyder 1330 engine 'sweet spot = sp' already figured out. For me I use 3k - 3,5k as my 'sp' for upshifts. Because I have a SE6 I just keep it at that 'sp' and upshift as I hear the 'sp' and check.
    For the downshifting, 90% of the time I let the Spyder do it's thing automatically..
    I hope this helps you. That's my story. ..........
    ENJOY YOUR LIFE WITH A SPYDER
    SoFlo
    Deleted
