Results 1 to 15 of 15
    Oct 2017
    Central NJ
    Default Trip odometer not working (temporarily)...
    2016 STS...16k+ miles...just had a 14k service done about a month ago.
    Went out for a group ryde today, and at my first fuel-up, I reset my Trip A odometer, as usual.
    About 2 miles down the road I noticed it was still on zero! I flipped to Trip B and this was working properly, so I reset this one and kept it on the display.
    About 60 miles later was our next fuel-up stop. A mile or so down the road, I checked Trip A again, and it was clocking properly.
    Both Trip A and Trip B continued to work properly, with a 60-mile difference, for the remainder of the trip, including another fuel-up 100 miles later.
    It seems like this was just a temporary "glitch".
    About a year ago, my cruise control stopped working for a day or two, but has been fine since.
    I guess these are just some random 'ghost in the machine' type issues, but if anyone has a reasonable explanation, I'd love to hear it.
    Thanks!
    Very Active Member ottawa-rider's Avatar
    Sep 2012
    Casselman, Ontario, Canada
    Well, first of all, it is possible to PAUSE the trip meters.
    However, even if you accidentally did pause it, I think you would know if you enabled it again.
    Just saying!
    2018 RT LTD , Black
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by ottawa-rider View Post
    Just saying!
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Durham,Maine
    And if you try to set your cruse at anything lower than 45 it will bock and not want to set! And if you have a weak brake peddle return spring and the peddle bounces just enough to get into the safety switch it will cancel out, don't ask me how I know that tid bit!!
    2012 RTL , Pearl
    Clinton, MS
    Just saying!
    How do you pause it?
    Dec 2018
    Long Island
    mph
    I have a road that is several miles long with no stop signs or traffic signals. The speed limit is 25 mph. I always set my cruise for 25-30 mph on that strip with no problem. I have a 2014 RT.
    And if you try to set your cruse at anything lower than 45 it will bock and not want to set! .....
    Quote Originally Posted by LongIsland View Post
    mph
    ....... I always set my cruise for 25-30 mph on that strip with no problem. I have a 2014 RT.
    Don't really know what it might've been that stopped your cruise control working a year or so back, Raprider; but cruise control won't set if your engine revs are too low for whatever gear you happen to be in/the road speed you happen to be travelling at... So if you are in saaay, something like 5th or 6th gear travelling at only 45 mph, your engine revs are likely too low for that speed and it's no wonder cruise won't set; but if you are in 2nd or maybe even 3rd gear doing 25mph, your engine revs will be somewhat higher in relation to the given road speed, so cruise will probably set fine!
    The 998's have a pause/resume feature on the trip meters.
    When the button shows "pause" it is working. When the button shows "resume" it is in pause. Sounds like you hit the wrong setting. Been there, done that myself.
    Durham,Maine
    Me to!!
    2012 RTL , Pearl
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    Me too. There are a number of things on Spyder readouts that appear backwards with regard to what they actually do.
    Oct 2017
    Central NJ
    Thanks, ARTraveler!
    I've never noticed this before and will take a look next time I'm ryding...maybe later today!
    Oct 2017
    Central NJ
    Thanks, Peter!
    I have had no problems since, and often set my cruise as low as 29mph, but the low rev situation may be relevant.
    Happily, it was a brief issue for a day or two and has not recurred since.
    Mar 2017
    Salisbury,NC
    NOT SURE for a 2019 with new gauge cluster. but on 2015 RTL, left - right arrows on handlebar toggle trip A/B. up - down arrows,,,,,,,down erases miles / hrs info. up pauses the trip from recording miles / hrs. 2019 with that joy stick would be something similiar
    Clinton, MS
    Quote Originally Posted by Woodaddict View Post
    On the 2019 pushing up on the joy stick makes the one you are on the primary to be displayed on the left side of the display.
    Oct 2017
    Central NJ
    Quote Originally Posted by Raprider View Post
    Thanks, ARTraveler!
    "Pause" found...yeah, I must have pushed the Up arrow in addition to the Right arrow (reset)...
