Results 1 to 14 of 14
    Active Member Rookiespyder's Avatar
    Jun 2017
    Hanover Ont Canada
    Default Front sprocket - trying to remove the bolt, any ideas?
    I have all of my panels off and my belt off. Now I am trying to get the bolt off that holds the sprocket on all it is doing is spinning in there even while I holding the sprocket in place does anyone have an idea how I can get the bolt out without it spinning in there.2015 RTL
    2015 RT Limited
    Jul 2011
    Mitchell, Ontario, Canada
    Put the belt back on and tension it back up. Lock the parking brake and try again.
    2018 F3 LIMITED
    Active Member ButterSmooth's Avatar
    Sep 2020
    Central Oregon
    Quote Originally Posted by Rookiespyder View Post
    If the sprocket isn't turning but the bolt and shaft are, you can try putting the bike in gear to hold the shaft. Be cautious about how much force you put on the bolt, since it will be applied to the transmission at the same time. It should hold well enough to 'break' the loctite on the threads, but I wouldn't put the full 110'# of force on the gears . Since the pulley slips on the shaft, it hopefully isn't torqued really tight.
    The belt would normally be used to hold the sprocket from turning, but since you say the sprocket is held in place I assume you found another way.
    Head in the game, eyes down the road... 2020RT
    Spyder Tryke Pylot
    2020 RT , Lamonster extender Petrol
    Northern Kalifornia
    Is that bolt Left or Right-hand thread?
    SoFlo
    Righty tighty, lefty loosey
    Dec 2013
    A rattle gun might help too! Got one, or know anyone who does have one??
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Sep 2014
    USA
    A bit of heat in that area will help too. Using a impact gun could break the bolt trying to get it off. Thats where the heat will help too.
    I am sure they used a bunch of thread locker on the threads.
    SoFlo
    Yes, heat the bolt head with a propane torch for a short bit, then, while hot, zip the bolt out with an impact gun.
    Northern Kalifornia
    Not so if it's left hand. I would guess it's right-handed but I'd find out for sure before I hooked an impact up to it.
    Northern Kalifornia
    If it's a "bolt" and you heat it up, it will expand it and may make it tighter.
    Oct 2013
    rome new york
    Heating the head of the bolt will do nothing, It the threads that hold it. Sorry elbow grease the only way
    SoFlo
    Quote Originally Posted by bmccaffrey View Post
    Incorrect, very common to heat the bolt head to free threadlocking compound.
    Sep 2014
    USA
    I do it all the time. Versus rounding out the bolt or snapping them off.
    Jun 2017
    Hanover Ont Canada
    I got it out with my electric impact and yes all of the teeth are worn off on the sprocket. Thanks for all of the ideas.
    2015 RT Limited
