Results 1 to 5 of 5
    Active Member Drwerner's Avatar
    Apr 2021
    NY
    Default High beam Wire Location
    I installed a set of driving lights that I want to come on with the high beams via a relay - anyone know where I can pick up the high beam wire? Thanks!
    2021 RT Limited , Marsala Red/Black
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    Find the wire that energizes the high beam shutter and tap into that. I did that on my 2011 RTS, worked fine.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Apr 2021
    NY
    Quote Originally Posted by Grandpot View Post
    Hi, thanks, exactly! But where or where is it?!
    Oct 2014
    Fort Mill, SC
    It's been several years since I did it and I have sold the unit, so here's an idea. If you remove the Tupperware that gives you access to change the headlight bulbs, you will see the shutter. Just tap a wire right at the shutter. If recall correctly, it is on the right side.
    1998 Honda Valkyrie
    US Navy Veteran
    Idaho
    Quote Originally Posted by Drwerner View Post
    Easiest place to get to it is behind the headlights. You'll have to remove a headlight to get to it.
    2014 Copper RTS
