Results 1 to 18 of 18
    Very Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    Question Shocks OR Swaybar
    2019 RTL, 350 pounds of people on the byke, seems to "dive" into corners. If I can only afford one, should I consider shocks or swaybar? If you recommend shocks, what kind? The swaybar I know about. Thanks -
    Jim
    Ryde, eat, sleep.... repeat
    2019 Spyder RT Limited Pearl White/Dark
    LaMonster drink holder with X-Grip
    LaMonster Belt Dampener
    Lamonster USB cable with extension
    Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
    Jun 2016
    indpls in
    sway bar easy and cheapest
    Quote Originally Posted by fatboy View Post
    .... Also with a SWAY bar, there really isn't any trade-off on ride quality..... Mike
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    Swaybar, will prove you right, it makes the ride so much better. Next thing is tires, then shocks, but if you're problem is solved with only a swaybar, then that's for sure the way to go..
    the funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it........
    Spyder F3s 2019 All Black ( Named it: Brutus)
    Carbon Items added, just for looks
    Upgraded Shocks Trac-Tive, Rear hi/lo and rebound adjustable, with Hydraulic Pre-Load adjuster
    fronts hi/lo and rebound adjustable, custom made by the Trac-Tive Guru's
    Swaybar (Ron's)
    Tyres Front Michelin Cross Climate+ 175/60-15
    Rear, for 2022 still a Kenda, next Yokohama Advan Fleva 205/55R15
    Exhaust Bone stock, with a RLS Cat- Delete
    Custom ECU-Mapping, rewritten/adapted to my Ridingstyle
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    SoFlo
    You did not mention if you still have oem tires.
    I had this same discussion with a friend that just bought a 2021 the other day.
    Told him, given the chance again on our 2014 RTS, it would be replace front tires with Federal Formozas first. Next would likely be the aftermarket Fox Shocks, then the swaybar. I like them all, but back then did swaybar, shocks, then tires.
    FWIW, my friends 2021 Spyder has about 200 miles since new, he ordered new front tires.
    Jan 2021
    Descanso, CA
    BG -- 2014 RT-S 77K miles (3rd owner): I'm half your weight (I ride solo) with Kenda tires, OEM shocks and OEM swaybar. When I started, corner turn-in was treacherous. Changed all tires to Vredestein Quatrac 5 (from Tire Rack). Corner turn-in is more predicable and mostly remains stable throughout the turn. Bumpsteer is about as expected and the steering linkage needs tightening so there is some wandering.
    So tires first.
    After that, it depends on whether comfort or cornering are more important. Comfort would be front shocks with the adjustable Fox's being affordable (I assume your air suspension is working properly). Cornering would be the BR's excellent swaybar.
    I'd like to note that BR says the valving on the OEM shocks is pretty good so you might want to talk to him about his cheaper solution -- front shock spring adjusters.
    2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
    2016 Royal Enfield Classic 500 Fair-Weather Mountain Bike
    Oct 2020
    Arizona
    I did Federals up front, then the sway bar, then BajaRon's shock adjusters, and finally a General tire out back. The stock shocks are not that bad, and the adjusters will allow you to adjust for your weight. After market shocks are ridiculously expensive, so I just went the adjuster route. My story and I am stilling with it.
    Aug 2020
    Minsk
    How to properly adjust the front oem fox shocks? I weigh 75 kilograms and sometimes a passenger 50.
    Jun 2016
    Harrington, Australia
    Quote Originally Posted by Sungate View Post
    Sungate, It would be better if you started your own thread to ask this question, for two reasons - First, it’s not considered polite to hijack someone else’s thread, and second, only those who are interested in BigGuy’s question will be reading this thread.
    If you aren’t sure how to do it - Select the Forum box at the top of the page, then select Spyder General Discussion, then select the Post New Thread box (in red). Enter a catchy heading and your question.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Jun 2016
    BigGuy, you’ve got 30lbs on me, and I’m on an F3......I went stabiliser bar first after experiencing what you are, and it made a significant difference. I later added Wilbers shocks all round, but that was more to cope with the very poor roads we have out here.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Apr 2019
    PA
    I ride 2-up 80 percent of the time. I’m 178 and wife is 160. Sway bar made a huge difference. The shock adjusters capped it off with new tires on front. My wife noticed immediately. Shock adjusters are 1 3/4 turn with both and fully loaded frunk, bags and trunk with rack bag I went 2 1/4 turns and it’s PERFECT! I noticed the quick turn solo.
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    I'll sort of swim against the current here. I say shocks. The sway bar won't prevent front end dive to the degree that proper spring rates on the shocks will do. Sway bars are kind of icing on the cake, but the cake is proper spring rates combined with proper shock settings (compression and rebound).
    A sway bar is much cheaper and might work, so to that end you can do it first with little to loose. However, the proper fix is with the shocks/springs set to you weight and riding style, combined with the sway bar.
    2020 RTL SE6
    Aug 2016
    All good information and I thank you all. Limited income for me makes me want to choose the swaybar for now. Save up, get the tires or shocks... eventually all three. Roads her in Northern Indiana and most places I ride are pretty decent. They do grade the unpaved roads as well... but they are few here. Thanks again.
    Jim
    Jan 2019
    Hunter Valley NSW Australia
    Quote Originally Posted by BigGuy66 View Post
    Jim
    I fiited new shocks and was going to get a sway bar but no longer see the need. I fitted Wilbers (cost $3500 approx) for all 3 corners. It has made the bike far better handling, better anti-dive behavior, no nervousness in rough corners, and as I tour a lot with my chief cook on the rear we are both able to cover much longer distances for the better ride and handling because we are less fatigued. I like to sport tour so at times its at the "upper end" of the speed "limit"
    My mates 14 RTL had the sway bar only, he and his wife rode mine and after 15mins I pulled them up to see what they thought, both had big grins on their faces due to how much better mine was to ride. He ordered M2 for his as they are a little cheaper and dont have the rear remote adjuster like the Wilbers
    Mine is a 17 RTL, I weigh approx 95kgs, better half approx 55kgs, but I recently took a long trip with a mate on the back who was 120kgs, and to my surprise we didn't bottom out once - I was expecting it with his weight but the adjustability allowed me to avoid it.
    I also find I have a better choice of behavior. With the OEM shocks, I had to adjust the rear to Maximum with my wife on the back, which did make it more harsh for us and the bike. With the Wilbers the rear height stays on mid wether I am sport riding or two up, the Shock valving and spring rate are far far better than the OEM. I used to race MX, sport tour and have always liked to have the ability to tune the suspension to the conditions or ride situation.
    2017 RTL
    2017 RTL , White
    Jun 2019
    Portugal
    Hi,
    I've got a 2011 Spyder RT and am also considering the Wilbers shocks.
    Can you please share a photo of them on the byke?
    How do you access the rear shock for adjusting? From below the bike?
    Do you know if they have several types of shocks for thes spyder or only one? Here in Europe i've only found one.
    Thank you
    Aug 2020
    Il
    For those that are mentioning sway bar, are you talking about replacing the sway bar ONLY or paired with the links? I have a new base F3 and am considering swaybar vs shocks.
    Apr 2019
    PA
    New swaybar and new links (heim joints) for me. Bought as one kit from bajaron. The OEM heims are plastic and totally under built in my opinion. Replace both!
    Dec 2013
    Quote Originally Posted by Pirate View Post
    Given the outstanding quality (NOT! ) of the OE Links, I reckon you'd be seriously silly NOT to include replacing the links AND the swaybar as a matching set - and at the same time too!!
    Regardless of how sloppy the flexible OE links will already be making your Spyder handling feel, it'll really only take just the one bum-puckering instant immediately after one of the OE links breaks halfway thru a turn, or worse yet, midway thru an emergency evasive manoeuvre, for you to think you were soo bloody STUPID for not having tossed the OE links at the earliest opportunity and fitted a quality set of Heim links and a matching high quality upgrade sway bar at the same time that you'll be kicking yourself about such an abject lack of forethought for years to come! . Do you really need to ask me how I know this?!?
    So if you even just vaguely think you might benefit from &/or want to upgrade the OE cheese stick... err, sorry, that should read 'OE swaybar' same/same tho! - just DO IT!! And upgrade the links at the same time! Just like swapping to 'real' car tires & running them at an appropriate (lower) pressure for the (lighter) load your Spyder/Ryker places on them, I doubt you'll ever regret it!
    Go On, DO IT! You Know You Want To!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
