Results 1 to 17 of 17
    Jan 2021
    Clemmons North Carolina
    Default Can someone help identify this? Is it falling off?
    Speaking of things vibrating off the bike now im looking over everything...and when i got to work this morning I saw this..gearchangerpicture1.jpggearchangerpicture2.jpg never really noticed it before but I never really looked to notice it either...lol...can some one tell me first what this is and second does it need a cover or did the cover also vibrate off as well...lol..
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by kennygee View Post
    Reverse Actuator
    2019 F3L , Covid Blue
    Jan 2021
    Quote Originally Posted by bikerchris1270 View Post
    Reverse Actuator
    ok gotcha...one last question does this have a cover because I don't remember seeing the whirring before today..Maybe im over thinking it..
    Apr 2020
    Edgerton,WI
    No cover
    Jan 2021
    No cover
    ok thanks for the quick response...so its just me being overly cautious because of my license plate housed just vibrated off the bike...lol
    Sep 2009
    La Valle, WI
    If you drive on and off a trailer. Make sure you dont get hung up on it. If you bend it your screwed. It wont shift into reverse. Some have done it with steep angled gates.
    2018 F3 Limited , Oxford Blue
    Sep 2014
    USA
    And dont put your jack under that area.
    Jan 2017
    PORT ARTHUR TEXAS
    Default Hung it up on the trailer
    Quote Originally Posted by JP58 View Post
    Unfortunately I did just that. Do I need to replace the actuator and bracket or just the bracket? Thanks in advance.
    Sep 2009
    La Valle, WI
    If you just bent the bracket and didn't break the actuator. Try just replacing the bracket.
    Dec 2013
    Quote Originally Posted by BYVION View Post
    You might get away with just carefully bending the bracket back & returning it all to its 'pre-jacked' position...
    Worth a shot tho! And then if you still can't select reverse, you can look at buying just a new/replacement bracket.
    Good Luck!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Jan 2017
    PORT ARTHUR TEXAS
    Too late. Lol. Already done that. Can’t find the sweet spot. Do I need just the bracket replaced or the actuator as well?
    Sep 2009
    La Valle, WI
    I dont know never bent one. Others on here have though.
    Dec 2013
    Usually, it's just a matter of replacing the bracket! Buuut....
    Aug 2007
    Greeneville, TN
    Would anyone mind if I pointed out that this is a stupidly engineered component? Seems like the elephant in the room.
    Sep 2009
    La Valle, WI
    Yes it is. BRP should have put a skid plate under it.
    Aug 2007
    Greeneville, TN
    A skid plate is one way to go. But this thing hangs down ridiculously low. A skid plate would simply exaggerate the problem. Why take a fairly fragile component and place it where it is almost sure to get whacked? Surely, there must be a way to tuck it up into a more protected position. It's almost like they pasted this on as an afterthought. I frankly just don't get it. Engineers looked at this and said; 'Oh ya! This is a GOOD Idea!'
    Very Active Member JKMSPYDER's Avatar
    Dec 2012
    Murphy, NC
    My reverse actuator switch failed twice and it was never bumped or damaged.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Spyderpops Brake/Run/Turn Signal LED's
    Lamonster Garage LED Fog Lights and Headlights
    2013 ST-S retired 1/9/16 at 25,061 miles
    2015 F3S sold at 77,565 miles.
    2015 F3-S , BajaRon Plugs Can-Am Red
