Results 1 to 4 of 4
    May 2021
    Henderson NV
    Default Only have Left Turn Signal blinkers! Any ideas?
    Hello
    i have a 2008 sm5, i only have left turn signal blinkers , the handle bar switch is new and did not fix the problem, i turn on left turn the left turn light flash, i turn on the right turn and only the left side flashes , all light flash with the hazards , there are not any burn out bulbs, no work was done just started doing this one day, i can use any help i can get to help find the problem,,, right know i seem to be going in circles
    thanks
    Bossier LoUiSiAna
    Kinda narrowed it down
    The switch may be new but sounds like a loose connection, Especially if all work with hazards. Just for testing try pushing in (cancel) as you toggle L/R
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    try adding some blinker fluid. The right side may need to be bled.
    2022 RT Limited , Silver w/ Black and Purple accents
    Feb 2019
    Portland, Oregon
    3 left turns = 1 right turn. Problem solved. You're welcome.
