Results 1 to 19 of 19
    Active Member kjweed's Avatar
    Jul 2017
    Syracuse NY
    Default Titan Trailer - how do I load so the Spyder front end won't catch?
    I have a 10' ft Titan aluminum Trailer for my can am spyder that has a drive on ramp. But I hear that if you drive up the ramp the front end of the Spyder will catch. Is this true? if so how to a load my 2013 Spyder?
    Thanks for any help
    2013 RT Limited
    2013 RT Limited , Black
    Oct 2020
    Arizona
    There are two catch points to be considered about. The nose as you start up the ramp and the belly at the breakover point at the top of the ramp.
    You got a lot more response on your FB page post. That trailer should not have an issue.
    PA
    No problem loading on Titon, it’s a 6 foot ramp I assume. If it’s to steep get 3- 2x8 12inch blocks. Screw the blocks together. Make 2 of them. With the trailer attached to the truck pull forward so the rear tires of the truck are on blocks. With the rear of the truck up now the rear of the trailer is closer to ground creating a lower pitched ramp. Once loaded drive off blocks, pick up blocks and drive away. Easy piezzy!
    Jul 2017
    Syracuse NY
    Quote Originally Posted by Wmoater View Post
    This is my trailer
    Last edited by Peter Aawen; 05-08-2021 at 06:54 PM. Reason: Fixed img/attach display commands
    2013 RT Limited
    Jun 2011
    Alamogordo, NM
    No trailer, but a nice pile of Rocks and a Chain Link Fence
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Mar 2013
    Marion, Arkansas
    Quote Originally Posted by old Timer View Post
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Nov 2020
    Lincoln, Nebraska
    I find if you back a Spyder RT onto the trailer the nose will not catch.
    May 2017
    Mesa, Arid-Zone-A
    Get two 2X10s five feet long. Put a long fastener through one end so it protrudes down an inch or two. Place the boards about half way up on your ramp with the fasteners protruding down between your ramp slots. The fasteners will prevent the boards from sliding out as you drive your Spyder up the boards. I think you will find there is no need to have a third "cheater ramp" for your rear wheel. I didn't. Good luck..... Jim
    Semper Fi
    Oct 2020
    Arizona
    Quote Originally Posted by kjweed View Post
    This is my trailer
    Trailer has what appears to be 6' ramp and dropped axle. Should load easy with correct height ball on the tow vehicle.
    Apr 2021
    Ky
    Loading at home could be different than unloading elsewhere, always go slow
    Active Member Eviltwin's Avatar
    Oct 2017
    Portsmouth VA
    I have an Aluma ten foot trailer and I had to do two things to fix that issue. First was to get an adjustable mount so I could raise the ball up some which put the back of the trailer down a bit lower and create a shallower angle. The second was to carry a couple of 2x10 cutoffs and put them down underneath the edge of the ramp to raise it up a bit. Between these two measures, I don't have any issues with the front scraping anymore.
    2019 BMW C650GT, 2010 Spyder RT-S, 2009 BMW R1200RT,(sold) 2009 Honda Silverwing (Sold), 2009 Kawasaki 500 Vulcan (Sold)
    2010 RT SE5 , Black
    Very Active Member Big F's Avatar
    Aug 2012
    Bellevue, NE
    a real easy solution is to change out the hitch on the truck with one a bit higher and the real end of the trailer will lower!! they make a gazillion hitches to fit into your receiver.. it doesn't take much increase in heigth to lower the trailer back end.. and your trailer will still appear to be level going down the road..
    BIG F
    Jan 2015
    southern WI
    Just consider all of the things you can do to reduce the ramp angle...ex: park the trailer wheels in a low spot, jack the front of the trailer up with the tongue jack, lay a 2x4 under the leading edge of the ramp, flip your drawbar to raise the ball if possible, park the vehicle wheels on a high spot, lengthen the ramp, if you live in town and there's an incline from driveway to street, park the trailer wheels in the lowest spot....you get the picture...It really doesn't take a lot to avoid the scrape...
    2016 RTS , Pearl White
    Durham,Maine
    There's a will, there's a way!! Use your head think out side the box!!
    2012 RTL , Pearl
    Active Member michrick's Avatar
    May 2015
    Liverpool, NY
    I do the same as cananjhb I use 2 - 4’ 2x10’s when I load my RT or my wife’s ST onto my Triton AUT 1472 no issues. My Triton has a bi-fold gate so it’s around 4’ long it’s not as long as your gate so you should be good. Just take it slow
    Hers 2014 ST
    His 2016 RT Limited
    2016 RT Limited , White
    Jul 2017
    Syracuse NY
    Thanks for all of the suggestions
    2013 RT Limited
    Jan 2015
    southern WI
    Quote Originally Posted by canamjhb View Post
    I've done something similar to this too
    Active Member Briorick's Avatar
    Apr 2021
    Southern IL
    Quote Originally Posted by Big F View Post
    BIG F
    Great advice!
    When I bought my Spyder, I found this to be the easiest method of all......and I just happen to have different drop down ball mounts for various uses over the years. Even using 2 x 4's under the rear trailer edge helps to raise the rear trailer height just enough to keep the front of the Spyder from bottoming out when loading and unloading. Just have to get creative. It can be mind boggling for sure.
    2014 RTS , Pearl White
    Mar 2018
    mississippi
    I have an issue with my RT dragging when I load it on my trailer. The simplest solution for me is I put a block under the trailer jack and jack the tongue up with it still hitched to my truck, it changes the angle of the trailer ramp and nothing drags.
    2015 Can Am Spyder RT Limited
    Magic Mirrors
    Short Antenna
    LaMonster Dual Power Plate
    LED Headlights
    LED Fog lights
    Vibration Damper
    Spyclops
    Spyclops II
    Utopia Back Rest
