Results 1 to 6 of 6
    Aug 2016
    Nashville, GA
    Default Wrong key showing on screen
    Guys, on my 2018 F-3 Limited which I bought new 2 1/2 years ago, sometimes when I switch it off to get gas and use my key to unlock the fuel tank cap, then when I re-insert my key and try to start the engine, I get a key notice on my screen like I don't have the right key! I switch it off and back on a couple time and it cranks and everything seems ok. What should I check out or do I have to take it back to the dealer?
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by south GA Farm Boy View Post
    Try a different key.
    Check for codes in menu of instrument cluster.
    Possible DESS antenna or module failing.
    Dealer time.
    2019 F3L , Covid Blue
    Bossier LoUiSiAna
    Quote Originally Posted by bikerchris1270 View Post
    Dealer time.
    However is it the only key if another transponder closer to antenna first one read wins. Don’t forget try the spare too have both if/when visiting dealer if any programming is needed.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Dealer time.
    If it's DESS issue ... the " orange screen of death " will appear ... not the KEY icon .... Mike
    Bryant, Arkansas
    Next time you get it serviced have them to get the computer to "RELEARN" BOTH Keys
    Active Member Bucketman's Avatar
    Jan 2015
    So WI
    My DESS code plus the Key Icon showed up the day after dealer changed tire and reset with buds. It works okay now but have concerns. I don't think it is coincidence.
