Results 1 to 9 of 9
    Apr 2021
    Oslo, norway.
    Default 2009 spyder rs catalyst and exhaust.
    Hi ya'll. I'm new here and a first time spyder owner. Just love my spyder and ride it as often as the weather here in norway allows me to. I do however want to upgrade the sound the engine makes. Wish it had a more beefy bark like a big V twin should. Could any one confirm for me that the catalyst is in the stock muffler? If so I believe just changing the muffler to an after market one with out the catalyst in there would do the trick. Seen a lot of people here talking about the cat delete pipe. Is that only necessary on the rt and newer models?
    Any help is very much appreciated.
    Have a good weekend everyone!
    Quote Originally Posted by Canamandy View Post
    The " catalyst " ie. Cat .... is separate from the muffler, and the " cat delete " will change the sound ( more mellow but not really loud )..... I did the cat-delete with the " baffle " on my 14 RT and like the sound.... Unless you can hear a sound clip for the after-market muffler ... it will be a lot of money that you might regret..... every after market muffler that I have heard is 2 to 3 times as loud as OEM. ... there WON'T be any improvement in power output., only sound and weight re-duction via the cat delete ...... Mike ....also
    Apr 2021
    Oslo, norway.
    Thanks for the info, it really helps. I'm not after more power, just a nicer sound. My stock set up sounds nice on tick over. As soon as I give a little gas it sounds like a little car.
    I saw some one else mention on a thread here some where that the RT and the spyders after 2013 have a cat b4 the muffler, but the pre 2013's spyder rs has the cat in the muffler. Would be an easy fix if that was true.
    Dec 2013
    I saw some one else mention on a thread here some where that the RT and the spyders after 2013 have a cat b4 the muffler, but the pre 2013's Spyder RS has the cat in the muffler. Would be an easy fix if that was true.
    I believe that IS the case!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Aug 2007
    Greeneville, TN
    In the 2008-2009 GS models, the catalytic converter is located within the muffler. Later models moved the cat to a separate component. Get rid of the muffler on your 2009, and you'll get rid of both items. That muffler is very heavy. I went through a good number of exhausts. Lamont went through more than I did. My favorite of all, (and still is) is my Yoshimura slip-on. It sounds very mean at WOT. But at cruse and normal riding, very nice sound. Not raspy, not obnoxious loud, and it never drones. Plus, other mufflers I had blew out after a relatively short time. The 998 is very hard on exhaust systems. Get a cheap muffler and you may find a hole in it. The Yoshimura is rebuildable. I rebuilt mine at about about 25k. But when I got in there, I was surprised that it really didn't need it. The packing was still in pretty good condition. Not bad for that kind of miles on a muffler.
    Of course I think it looks good. But that is a subjective opinion.
    This is the one I settled on (oval version). I run it with the optional restrictor. The 998 runs better with just a bit of restriction.
    I also like and considered this triangular model. Pretty much the same functionally, just a different look. Both models come in Carbon Fiber and Stainless.
    Apr 2021
    Oslo, norway.
    Thanks for the tip bajaRon. I'll see where I can get a yoshimura from.
    Apr 2021
    Oslo, norway.
    I found a yoshimura r-77, is it the same exhaust???
    Aug 2007
    Greeneville, TN
    Similar, but not the same. This is a shorter pipe.
    R-77 Product Dimensions 18.7" long x 5.1" wide.
    The RS-3 Oval Yoshimura I am running is longer. I can't seem to find actual dimensions. The numbers I am getting must include some piping or maybe the packaged size, because they are too big.
    The triangle version I mentioned is the TRS model. This too is a longer muffler than the R-77. Again numbers are too bit and must include more than just the muffler. I will measure my RS-3 on Monday and let you know. I think the longer pipe gives you a better sound. Short may look cool. But it will be loud and probably raspy. The exit is much closer to your ear as well. Not what I was looking for.
    Apr 2021
    Oslo, norway.
    I'll take your recommendation and ask my bike shop for a RS3 when they open again. Everything here is still on lock down. Hopefully in a few weeks I can ask them to order me one.
