Must Have's for Frunk?
I am getting a Ryker 900 shortly and wanted to hear from you about the 'must have's' to carry with you. I have a LinQ bag, but may not always have it attached. What are some things you all think I should have with me at all times? I'm thinking:
tire pressure gauge
pen/notepad
charging cable for phone
zip ties
Any other suggestions would be appreciated. Thanks!
Rain gear, sun block, phone charger.
(sarcasm) Wallet with creditcard, and loose change, few bottles of water/ or spirits, helmet, gloves, etc. etc. Just Kidding
the funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it........
Spyder F3s 2019 All Black ( Named it: Brutus)
Carbon Items added, just for looks
Upgraded Shocks Trac-Tive, Rear hi/lo and rebound adjustable, with Hydraulic Pre-Load adjuster
fronts hi/lo and rebound adjustable, custom made by the Trac-Tive Guru's
Swaybar (Ron's)
Tyres Front Michelin Cross Climate+ 175/60-15
Rear, for 2022 still a Kenda, next Yokohama Advan Fleva 205/55R15
Exhaust Bone stock, with a RLS Cat- Delete
Custom ECU-Mapping, rewritten/adapted to my Ridingstyle
Pedalbox, Awesome Upgrade...
Get the glove box organizer. Useful pockets to keep all that stuff organized.
https://www.slingmods.com/canam-ryke...pnel?vehicle=4
MWO (Ret'd) SJ Barnes
‘20 RTL Stone Grey
named Britannia in honour of EE Doc Smith’s
Grey Lensman’s ship.
Farkles:
Bestem Carplay
canamsypderaccessories hitch and wiring harness,
showchrome trunk rack,
12v AND dual USB direct to battery in the frunk,
dual USB switched in the blank console switch spot (parasites the power off the seat heater switch),
frunk lid organizer,
trunk organizer,
showchrome rider backrest,
ryder and passenger cup holders,
ram mount for the iPad mini I use for GPS
quadlock phone mount
Nautilus horn
Data blocker on the glove box USB
Big Bike Parts highway pegs
Spyderzone dash pouch
Convex mirrors
‘20 Ryker 900 (my wife’s ryde)
Farkles
Slingmods fwd/rev ‘suicide shifter’
frunk organizer
dual horn
Max mount
Rear seat with tall back rest (not mounted)
Ryder backrest (not mounted)
Side bag
Top bag
top bag makes a good backrest. Will swap on the rear seat if she ever wants to 2up
23 Moto Guzzi V7-850 SE 23 Yamaha XT250 18 Yamaha Bolt R-Spec 22 Triumph Street Twin 20 CanAM Ryker 900 14 Honda CB1100 18 Yamaha XT250 16 Moto Guzzi V7 II 17 Yamaha TW200 12 Triumph Bonneville 02 Sportster 1200 Sport 03 Sportster 883 76 Honda CB750F 75 Honda CB360 70 Yamaha CT1 72 Yamaha CT2 72 Yamaha AT2/CT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda CB160 62 Honda CA110
2020 900 , NGK 4218 iridium CR8EIX Matte black
Awesome - Thanks for the pics - that really helps.
Flashlight & Letherman Tool
2014 ST-L
From Sportster Doc's post
That installation on the rear fender looks so clean and purposeful, absolutely functional. Well done!
What kind of fender bag is that?
I carry a tire plug kit and compressor. Also a butane soldering iron and some solder. Has come in handy several times on other bikes. I've spliced an SAE connector on the compressor that plugs into the SAE in my frunk.
"Love 'em all.... Let GOD sort 'em out!"
2021 RTL Dark Chalk Metallic with comfort seat
1978 GL1000 w/'75 engine show bike
1976 RD400c
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2018 F3 Limited - Intense Red Pearl . . . . . . . . . . . . . . . . . . . . . . . . . . .
Tooth brush to get the bugs off your teeth.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
A spellchecker? <G>
Some nice suggestions though. I'd at least pack some hobby wire, duck tape, a bungie net, and a tire repair kit.
Remember it gets hot in there! Make sure whatever you put in it can withstand the heat. I put aluminum insulating tape on the exterior similar to what Slingmods sells, but I bought a roll for about $10 that worked perfectly.
Daily driving city or to and from work not much, small tool kit is about all, long trip as much necessities as possible. Tools, wire, tape, first aid, tire kit, extra water (even if hot it's still water) rain gear and what ever else I can think of and fit in the side bags for the trip. Frunk/trunk gets the travel bags and needed items for over night stay.
2021 Sea to Sky , cyclops light, front fender light/turn signal, rear run/brake/ turn signal LED strip, BRP floor board light Green
Mine is permanently stocked with
- Tyre Gauge
- Tyre Valve extension
- Visor Wipes
- Micro Fibre cloth
- Owners Manual (only because I'd forget it when I go for a service, and at 200KMs to get there, I cant just drop back to get it)
- Rainex and open weave soft cloth for it in Ziplock bag
- Intercom Cheat Sheet laminated (for when it goes into some mode and need a PhD to get it back to normal)
- Shopping bag (for that run to the supermarket or wet/muddy/dirty clothes)
- 2 x plasticised cable bike locks for when we travel to attach helmets to pillion hand grips
I put the stuff from my pockets in the frunk.. I bought a motorcycle license plate stash box that goes where the rear license plate goes and keep my registration, insurance, tire plug kit, apple airtag, co2 cartridge (to fill tire) in it.
2021 Sea to Sky
Tags for this Thread
